BOBDITTS official build thread
Old Nov 8, 2007 | 12:31 AM
  #61
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: BOBDITTS official build thread
ORIGINAL: cloak01ls
ORIGINAL: bobditts
OK guys. Help me out here. Im wiring up the alarm right now (first time ever with an alarm). Im looking for the negative door trigger. The documentaion I have says it is under the dash light. WTF dash light are they talking about?!?!?! It doesnt help that there are 2 other white wires under the dash that are for other things. Help me out billy!?!
You can test the white wires under the dash with a DMM if you have one. But, you should be able to grab it in either driver or passenger kick panel as well...
makes sense. Im going to check the wire bundles now.
Old Nov 8, 2007 | 12:48 AM
  #62
bobditts's Avatar
you are a genious. The door trigger is right where it should be and easy to get to. My common sense isnt working too well tonight. thanks for the help.
Old Nov 8, 2007 | 01:01 AM
  #63
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
ORIGINAL: bobditts
No problem, glad I could help...
Old Nov 8, 2007 | 01:58 AM
  #64
bobditts's Avatar
one last quesiton (hopefully). The negative door trigger and the domelight supervision wires.... can I hook both of them up to the door trigger switch? I know i will have to use a relay for the domelight supervision but both wires are looking for a negative signal when the door is opened. Or should I actually wire the domelight supervision to the real domelight wire since a thief could come through either door?
Old Nov 8, 2007 | 02:29 AM
  #65
hillbillyinOhio's Avatar
one trigger does both doors. if you go to the courtesy light under the dash, white wire there. (one that illuminates your feet when the door is open)
Old Nov 8, 2007 | 02:35 AM
  #66
bobditts's Avatar
I dont have a light that illuminates my feet. That is what must be throwing me off. so you are telling me that the pin trigger on the body of the car that is exposed when the door is open will trigger for both doors even if I only use the drivers side door for the connections?
Old Nov 8, 2007 | 02:39 AM
  #67
that is correct.
Old Nov 8, 2007 | 02:40 AM
  #68
bobditts's Avatar
Thanks pat. Back down to the garage to slave some more. I really havent gotten all that far. This is all new to me. I will hopefully have it all done by 6am
Old Nov 8, 2007 | 02:46 AM
  #69
jeez. i wish i lived close to ya. have this things knocked out in about a half hour!
Old Nov 8, 2007 | 05:32 AM
  #70
bobditts's Avatar
that fast? damn! Well im almost done. I just have the led and the valet switch to install. I wont be able to test it out until later today (when the sun is up) because my GF is sleeping and I dont want to wake her up.
