box design help
Old Sep 13, 2008 | 09:59 PM
pimpinblazer91's Avatar
pimpinblazer91 is an unknown quantity at this point
Default RE: box design help
Blazin_Jason is that box big enough for that sub if every thing goes well ill be the new owner of a 15 bl also what was involved in building that box? thats the exact way i want mine just with an amp drawer under it more details would be great
Old Sep 13, 2008 | 10:06 PM
Blazin_Jason's Avatar
I sort of did something like that. Read this maybe? Yes the box I built was about 4 cubes which is on the larger end. Have you built a box before?
Old Sep 13, 2008 | 10:24 PM
yea ive built a few boxes just not with aero ports i looked at that psp website for those ports and i only saw 4x17 what did you do cut them down a little bit? i actually read your post there a while back. and what do you mean by internal dimensions? is that from the inside edge of the wood?
Old Sep 13, 2008 | 10:25 PM
forgot to ask whats involved in a double baffel flush mount is it just 2 pieces of wood just ones different size for it to sink in?
Old Sep 13, 2008 | 10:45 PM
Yes the ports come at 17" long, the main tube can be easily cut with a dremel or whatever. Basically the internal dimensions is what you use to calculate the air space. So your max width is 38" - (0.75 + 0.75) = 36.5", assuming 3/4" MDF as I wouldn't use anything less. I could figure out the depth and height, but I don't know since you want the drawer underneath it. For the double baffle it is basically 2 layers of MDF. The first layer has the sub Cut ID: 14.125â€, and then the top layer is Sub OD: 15.625†hole size. That allows the cub to sit down flush. You don't need to do that though, but it looks pretty
Old Sep 13, 2008 | 10:54 PM
ok so the ports are pretty simple can you just tell me the dimensions of your box that would make it easier because im pretty much going for the same thing. yea i like the look of the double baffle too so i think im gonna give it a try also on the amp drawer could i just make the walls of the box like 6 inches longer and put a seperate slot connected right to the sub box like build the box to the dimensions then just cut like 6 inches extra the bottom and put the floor in where it should be and then put the drawer where the other 6 inches are if that makes sence to you?
Old Sep 13, 2008 | 11:00 PM
Sort of follow you. I wouldn't put the amp in a completely sealed area though. That's why I installed the fans. Any reason why you don't want it on the box or something?
Old Sep 13, 2008 | 11:04 PM
well right now i have my amps on a little flap thing behind the seats (comes factory on my year) and i dont like the way it looks like cleanlyness and ive actually split a wire folding my seat back up once so i want to move them from there and i dont really want them on the box either cuz of the cleanlyness reason again i just think the drawer is the cleanest most efficient way and yea i was planning on putting in 2 cooling fansand maybe some breathing holes hidden somewhere
Old Sep 14, 2008 | 01:55 PM
What amp are you planning on using?
Old Sep 14, 2008 | 03:47 PM
i have a kicker zx 1000 and a kicker zx 350 for my door speakers
