box size questions
Old Feb 8, 2008 | 08:24 PM
pimpinblazer91's Avatar
pimpinblazer91 is an unknown quantity at this point
Default box size questions
ok so im getting a fi 15" and i cant find box plans that i want. i was hopeing someone on here can help me out with the demensions. i need it only to be 14 inches tall though and the sub aimed up with the port facing back so if some one can give me box dimensions for this sub it would be great heres the details on the sub thanks
DUAL 1 | DUAL 2
Fs: 25.9 Hz | 25.3 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 4.78 | 4.89
Qes: .65 | ..58
Qts: .57 | .52
Mms: 246g | 258g
Cms: 0.15mm/N | 0.15mm/N
Sd: 810cm^2 | 810cm^2
Vas: 141.3 l | 141.3 l
Spl: 87.6dB 1W/1m | 87.8dB 1W/1m
Bl: 9.3 N/A | 00.0 N/A
Xmax: 21mm
Rms: 800W
Sealed box: N/A cuft
Ported box: 3-4 cuft @ 33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.000”
Displacement: 0.17cuft
Old Feb 8, 2008 | 08:49 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: box size questions
what do you want the port tuned to?
Old Feb 8, 2008 | 08:52 PM
oh yah forgot about that i was thinking 32 hz
Old Feb 8, 2008 | 09:43 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
3.4 cubes @ 32Hz...
36W x 14T x 18.5D
VW: 3"
VH: 12.5"
VL: 24"
Just a real quick one.
Old Feb 8, 2008 | 10:16 PM
bobditts's Avatar
ORIGINAL: cloak01ls
3.4 cubes @ 32Hz...
36W x 14T x 18D
VW: 3"
VH: 12.5"
VL: 24"
are you taking the sub displacement into account?
Old Feb 8, 2008 | 10:22 PM
cloak01ls's Avatar
ORIGINAL: bobditts
ORIGINAL: cloak01ls
3.4 cubes @ 32Hz...
36W x 14T x 18D
VW: 3"
VH: 12.5"
VL: 24"
Yes I calculated for displacement. But I made a typo too, supposed to be 18.5" Depth
Old Feb 9, 2008 | 08:00 PM
blazinloud's Avatar
thread *****!
have you seen any positive effects with the subs firing up at an angle towards the glass....or would that just mess up the port design......just a random thought i had the other day....
Old Feb 9, 2008 | 09:54 PM
cloak01ls's Avatar
ORIGINAL: blazinloud
In the 2 doors, the near 45 degree back glass does wonders with up firing designs. I havent done too much experimenting so I can say conclusively that aiming toward the glass will have negative effects, but when you get into wierd angles sometimes you start seeing more cancellation.
Old Feb 10, 2008 | 08:46 AM
blazinloud's Avatar
ahh, thanks for the reply
Old Feb 10, 2008 | 09:20 AM
3.4 cubes @ 32Hz...
36W x 14T x 18.5D
VW: 3"
VH: 12.5"
VL: 24"
so these are the exact demensions i would need for my box?
chris015
Oct 14, 2011 10:47 AM
AKCoastie
13
Nov 1, 2010 03:41 AM
88s10Blazer
Jun 15, 2010 10:10 PM
jag2791
Nov 5, 2009 06:49 PM
rick465
Aug 25, 2006 09:37 PM
