box size questions
ok so im getting a fi 15" and i cant find box plans that i want. i was hopeing someone on here can help me out with the demensions. i need it only to be 14 inches tall though and the sub aimed up with the port facing back so if some one can give me box dimensions for this sub it would be great heres the details on the sub thanks
DUAL 1 | DUAL 2
Fs: 25.9 Hz | 25.3 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 4.78 | 4.89
Qes: .65 | ..58
Qts: .57 | .52
Mms: 246g | 258g
Cms: 0.15mm/N | 0.15mm/N
Sd: 810cm^2 | 810cm^2
Vas: 141.3 l | 141.3 l
Spl: 87.6dB 1W/1m | 87.8dB 1W/1m
Bl: 9.3 N/A | 00.0 N/A
Xmax: 21mm
Rms: 800W
Sealed box: N/A cuft
Ported box: 3-4 cuft @ 33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.000”
Displacement: 0.17cuft
DUAL 1 | DUAL 2
Qms: 4.78 | 4.89
Qes: .65 | ..58
Qts: .57 | .52
Mms: 246g | 258g
Xmax: 21mm
Rms: 800W
Sub OD: 15.625”
Cut ID: 14.125”
ORIGINAL: bobditts
are you taking the sub displacement into account?
ORIGINAL: cloak01ls
3.4 cubes @ 32Hz...
36W x 14T x 18D
VW: 3"
VH: 12.5"
VL: 24"
Just a real quick one.
3.4 cubes @ 32Hz...
36W x 14T x 18D
VW: 3"
VH: 12.5"
VL: 24"
thread *****!
have you seen any positive effects with the subs firing up at an angle towards the glass....or would that just mess up the port design......just a random thought i had the other day....
ORIGINAL: blazinloud
chris015
Oct 14, 2011 10:47 AM
AKCoastie
13
Nov 1, 2010 03:41 AM
jag2791
Nov 5, 2009 06:49 PM
rick465
Aug 25, 2006 09:37 PM
