Calling all audio gurus
Old Sep 15, 2012 | 09:37 AM
99lsdriven's Avatar
99lsdriven is on a distinguished road
By the way alton, since you helped me with finding the source of my amp problem, could you possibly tell me what transistors my amp (hifonics titan txi 7508) is running or where I can find out? I can't find the information anywhere and I want to get this thing fixed.
Old Sep 17, 2012 | 06:14 AM
altoncustomtech's Avatar
Getting the number off the transistors for replacements is easy enough, but ensuring that nothing else is burnt, and that it's all still working correctly could be an all together different matter. Unless the transistors are burnt up, you should be able to read the numbers right off of them. However, if you want to go this route you're cheaper off getting the little insulators (available at places like Parts Express: the #1 source for audio, video & speaker building components) and seeing if it fires back up on its own. If none of the transistors are burnt (all perfectly readable, no swelling, no burn marks) and nothing else looks burnt and it doesn't fire up on its own with new insulators then chances are you won't be able to repair it yourself without the proper test equipment, prior knowledge of how amplifiers work, and quite possibly not without the schematics and other information from the manufacturer that tells you what voltages, signals and such are supposed to be at what points. At that point you have to ask yourself if the amp is worth sending off to be repaired or if it would be cheaper in the long run to simply replace it.
Old Sep 21, 2012 | 01:48 PM
99lsdriven's Avatar
I pulled all of the transistors back so that they were about a quarter inch from the chasis of the amp, it worked for about 5 minutes and then went into protection mode. It has two different sizes of transistors, the small ones have numbers on them but the larger ones don't. There is no swelling or burn marks, I haven't gotten a chance to put a meter on the poor thing. I think it may be getting time to lay it to rest.
Old Sep 21, 2012 | 03:57 PM
rriddle3's Avatar
*I moved the above 3 posts from the 'For Sale' thread Sundown Audio SAE-1200D since they do not concern the item for sale.
chevylover5
Aug 1, 2014 02:58 PM
xgiovannix12
Jun 13, 2013 11:52 PM
BluFbdy
Nov 20, 2010 04:35 AM
HCCAFan
Mar 27, 2006 03:25 PM
