Component placement question
Old Mar 16, 2008 | 04:14 PM
dbleon's Avatar
dbleon is an unknown quantity at this point
Default Component placement question
Which of these two placements will provide the best sounding setup? The components are infinity kappa perfect 6.1's... Thanks
Old Mar 16, 2008 | 04:52 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: Component placement question
placement will be less of an issue than aiming. For the best sound, you need to try each possibility in a temporary setup. No one will be able to tell you which will sound best unless they have used the exact same speakers in the kicks and has already tried each possibility. Also, keep in mind that if the components are brand new, they need to be broken in for optimal sound. This will effect your sound and judgement when trying out the different placememnts.
thrash902
Jan 28, 2010 06:58 PM
hockeykid15
May 5, 2007 02:51 PM
rick465
Aug 25, 2006 09:37 PM
jerickso
Apr 20, 2006 11:05 PM
blazinloud
Feb 23, 2006 09:42 PM
