Concerned about speaker depth
Greetings all.
New ride (to me, at least); '04 Blazer 2-door. I'm getting excited about the opportunity to upgrade the stereo, but a search here has revealed that I've got serious speaker depth concerns! I gather I'm looking at the following:
Rear: 6x9
Front door: 6.75
Dash: 4x6
My major concern is how much depth I've got to get these in. Specifically the front door (concerned about how far down the power window travels) and the dash (I want to put in 4x6 plates w/ tweeters - am I going to end up using the stock plates and dropping in an aftermarket tweeter, or can I go with the 4x6 plates I'm looking at)?
Thanks!
Rear: 6x9
Front door: 6.75
Dash: 4x6
Thanks!
RE: Concerned about speaker depth
the dash is easy to get to, 2 scerw holding the trim on and you don't have to take the whole dash apart. i put 6.5 in fosgates in the door using the factory adapter. I have a 97 though. not sure if this helps or not.
Thanks seberg! Good info. I'd seen the screws on the dash and was hoping the grilles weren't pressure-mounted. Did you replace the dash speakers? If so, how deep is the hold for installation (want to avoid my plasma torch if I can)?
my blazer didn't come with speakers in the dash, Just a coupleof loose wires. It looks pretty easy to install. I didn't do any measuring. I bought a 4 way cd player and i have the front door and rear door speakers going. I don't want to go through the trouble wiring an amp. just for another set of speakers. Did you look to see if there are factory speakers there? I think it came with the premium sound system, not sure though. Good luck!
ORIGINAL: c_seberg
For the dash I just modified the factory 4x6 plate to accept 1in tweeter. In the doors I put in speakers that from very top of the speaker to the bottom of the magnet was about 3in to 3 1/4 in and I used the factory mounting behind the door panel and I had no clearance problems, and for the rear I found there was lots of room. I have an 05 2dr
ORIGINAL: Dabber
Did you put a full-range or a midbass in the door?
Thanks!
plenty of room in the doors for speakers. I had an issue because i put 6.8's in the front doors. I took an abs sheet and cut it to size for the dash and put a vifa sweeter in it. and the vifa was about 3 inches deep.
Thanks hillbilly! One last ? Most in here seem to advocate tweeter in dash with midbass in door. What do you think about that approach?
I wanted to put my 3 way 4x6 in the dash... but the hole isn't deep enough for the magnet, lol, I could do it easilly if I didn't want speaker grills, but....
