curious enclosure question
Old Feb 18, 2008 | 10:48 AM
jimbosv650's Avatar
jimbosv650 is an unknown quantity at this point
Default curious enclosure question
I tried searching but no luck. For the audio experts on here-- I currently have a Premier 2504spl 10" sub in an enclosed box powered by a Soundstorm 1200 watt amp. I know everyone hates bass tubes, but I havnt come across anyone whos swapped the sub for their own. In other words-- If I put my sub in a tube will it sound like crap? Its out of curiousity.
Old Feb 18, 2008 | 11:32 AM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: curious enclosure question
If its one of those prefab tubes yes it will sound like crap.
If your talking about a sonotube . you can get some pretty good bass.
Old Feb 18, 2008 | 11:42 AM
XBlazer01's Avatar
heres an example of one for an 8" AA Assassin with a 3" aero on the end
What you need is Sonotube (can be picked up at a lowes or home depot) Then you need to construct some MDF Baffles. Then matt and resin.
Your set.
heres the equation needed to calculate the volume v=pie(r^2)h
Old Feb 18, 2008 | 12:46 PM
jimbosv650's Avatar
wow thanks this might be a good/fairly cheap experiment
Old Feb 18, 2008 | 01:36 PM
jimbosv650's Avatar
more questions-- please forgive my ignorance, Ive never tried this before
what if instead of the sonotube treated with resin, I use a thick pvc pipe and insulate it. Would that be rigid enough?
also, how would I go about making baffles
Old Feb 18, 2008 | 01:50 PM
XBlazer01's Avatar
You prolly wanna still resin them for strength.
For the baffle just cut MDF rings.
iirc this is what Scott Owens was using before he switched to the 6th order.
tibby
Jul 12, 2013 08:48 AM
ripoffblazer
Jun 7, 2007 10:06 AM
vagnozzi
14
Apr 27, 2007 12:33 PM
juscarter
Dec 26, 2006 09:53 AM
TheDesertFox
Aug 15, 2006 01:07 AM
