do any one know
Old Mar 29, 2008 | 07:22 PM
strong blazer's Avatar
strong blazer is an unknown quantity at this point
Default do any one know
i was wondering about how to tune a n speaker box i have an ported box that i made to spec of my 2 12 and was wondering how do i tune it so that the would hit harder
Old Mar 29, 2008 | 08:01 PM
dbleon's Avatar
dbleon is an unknown quantity at this point
Default RE: do any one know
The tuning is in the port size/shape... if you built it "to spec" theres nothing more you can do other than constucting a new enclosure.
Old Mar 29, 2008 | 08:07 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Old Mar 29, 2008 | 09:56 PM
bigjsp's Avatar
bigjsp is an unknown quantity at this point
you can always add blocks to the inside of the enclosure to reduce the volume. Chucks of 2x4 dry wall screwed inside is a great temporary test.
This generally brings the tuning frequency up, so try to oversize a box when you build it because you can always make it smaller.
Another quick fix is to just block your port and see how it responds to being a sealed enclosure
Old Mar 29, 2008 | 11:17 PM
dbleon's Avatar
ORIGINAL: bigjsp
Generally a ported enclosure is much larger than its sealed counterpart, so sealing a ported box up will make it sound really bad. If you want to test the size, use a phone book or something similar. 2x2 strips wok great if you want a permenant setup... they will increase the strength of the enclosure too.
Old Mar 30, 2008 | 09:45 AM
i think the easier way to do this is to build another box but let be bigger so i could get the port tuned the way want it thanks guys
97Beater4WD
Mar 24, 2012 03:46 PM
JasinP
Jan 26, 2011 11:41 PM
jjsmith1228
Oct 26, 2010 05:45 AM
johnwiseman
Lifting Tech
Nov 3, 2008 09:51 PM
chevblazer02
Tires and Wheels
Nov 30, 2007 05:55 PM
