Any one know the size of the Rear Shock Upper retaining bolts '97 S-10 Blazer?
Old Jan 26, 2011 | 08:53 PM
JasinP's Avatar
JasinP is on a distinguished road
Default Any one know the size of the Rear Shock Upper retaining bolts '97 S-10 Blazer?
I had to have my rear shock upper retaining bolts cut off with a welder and cant take them in to see the size of the bolts as they are melted puddles of steel now. any one know the exact size of the bolts used on the rear shocks? any help would be greatly appreciated. I cant find anything online about it. all I know is they are 1/2" hex heads.
Thank you in advance!
Jason (Buckeye Blazer)
Old Jan 26, 2011 | 09:40 PM
KM346's Avatar
KM346 will become famous soon enough
I believe they are m8x1.25x25mm, if you melted them out then your also going to need the retaining U nut that they screw into.
Old Jan 26, 2011 | 11:41 PM
old skool luvr's Avatar
i think you're right about them being a M8 thread, but you can use whatever size you want now. like 5/16. same "size" as a M8, but you'll need to get the correct spring clip nut for whatever bolt you use.
zr2dan
Suspension Tech
Aug 2, 2013 06:45 PM
doitmydamnself
Feb 9, 2013 05:37 PM
1987blazers15
Nov 28, 2009 08:52 PM
offskooring
Feb 15, 2009 06:09 PM
speeddemon560
Mar 13, 2007 04:22 PM
