Double Din install on 1997 Blazer?
Old Aug 8, 2007 | 11:34 AM
Blazerx85's Avatar
Blazerx85 is an unknown quantity at this point
Default Double Din install on 1997 Blazer?
I was looking to install a double din cd/dvd player into my 97 blazer, is this possible? I hate the little gap under the single din cd player. It does not fit anything I have and is just stupid. I thought the stock cd player was double din. What has to be done to install a double din into my Blazer. Thanks in advanced
Old Aug 8, 2007 | 08:33 PM
hillbillyinOhio's Avatar
Default RE: Double Din install on 1997 Blazer?
it will require fabbing a new place that will cover the pocket as well. (factory pocket) . I was just going to use a sheet of mdr and cover with abs plastic. you will need to figure out a moun for the bottom of the radio. Buy the dash kit for your truck, and cut out most of it. leaving only top mounts, and the side bars. cut out the rest.
Old Aug 11, 2007 | 02:13 AM
ayedol's Avatar
ayedol is an unknown quantity at this point
Hello I am new in this forum, I have Blazer 2000 and want to know if I can install the JVC Double DIN CD Receiver - KW-XG700.
My Blazer is double Dim?
Thank You for your helps
Spanish:
Hola soy nuevo en este forum, tengo una Blazer 2000 y quiero saber si puedo instalar el JVC Double DIN CD Receiver - KW-XG700.
Mi Blazer es Doble Din?
Gracias por su ayuda
Link the Radio:
clicky
Old Aug 11, 2007 | 07:56 AM
no you cannot put a double din in a 2000 blazer. 2002, yes.
Old Aug 13, 2007 | 10:22 PM
getonerd's Avatar
getonerd is an unknown quantity at this point
how about on 2002 Xtremes
Old Sep 9, 2007 | 10:15 AM
velodyne's Avatar
velodyne is an unknown quantity at this point
I put a double din touchscreen alpine in my 2000 blazer. Just gotta cut and modify a bit
Old Sep 11, 2007 | 10:47 AM
mdk681's Avatar
mdk681 is an unknown quantity at this point
velodyne is right, there will be modification in a 2000
Old May 3, 2008 | 01:51 AM
Hot Rod's Avatar
Hot Rod is an unknown quantity at this point
I would like to do the same in my 1999. Anyone has some pics?
I know it will require some modifications.
Blazerx85: Did you install it?
msu12
Jun 14, 2019 12:33 AM
julioAKAjunior
Oct 9, 2012 11:29 AM
97Beater4WD
Feb 15, 2012 12:17 PM
scott_wheels
Jan 25, 2010 11:40 AM
Arthur
Mar 20, 2008 05:42 PM
