Eletronics and cold
will super cold tempretures harm audio electronics in anyway?
its suppose to be getting preety cold at night now a days and this week its suppose to be getting down to -14F at some point in the night
Shouldn't. CDs and/or the laser lens will probably fog up at first when you drive in the morning and cause some skipping.
and my friend believes that some people have blown out there subs from the foam ring around them being so cold that they have craked
could be, ive had similar problems.....it gets really cold here.
just play it low for a few minutes.....it dosent take long to warm everything up once its playing.
surrounds are made off all different types of material....who knows what could happen in -40 degree weather.
I had a PPI DCX 15 and the glue on the surround deteriorated in winter.
but my current subs do fine.
Keep your volume low... But loud enough that everything is ticking overfor the first 5 - 10 minutes or so and you'll be fine... Actually, a good way to say your subs + speakers are good to go, is if it's idling, when you start getting heat out of the vents, to be on the safe side.
I've run my stuff at MUCH colder than -14*F and had no issues.
The fan in my Alpine deck has a bad bearing, and when it's cold, it screeches... usually, by the time it stops, my speakers are good to go, lol
ORIGINAL: Mr Blazer LT
Like everyone else said, I would just keep it down for a couple minutes and you should be fine.
an240172
11-18-2009 09:32 AM
ravenhurst
15
04-26-2009 07:53 AM
as2higpark
10-18-2007 12:18 PM
beilharzc
03-12-2006 01:50 AM
