Factory BOSE system... PLEASE Help
Old Aug 24, 2012 | 03:22 PM
guitarsjm's Avatar
guitarsjm is on a distinguished road
Default Factory BOSE system... PLEASE Help
i know there is a thread for this but the answers dont fit me. my system is in a 2000 bravada... same as a jimmy i guess. amp is in bottom of center console, under the cd changer. my problem is the same as the other bose thread; all speakers went out, except for the front door woofers. it had all worked fantastic until just going out. i like the system and the sound was great for my taste. i have gotten TO the amp, just cant figure how to get it out without using a sawzall or jaws of life! i almost took a crow bar to it! i like the steering controls and the head unit is in perfect condition. i can find a bose amp to swap.. just need to know how to get this one out! its cheaper too than an entire new system. if i were to get that 4 channel conversion unit from crutchfield, what does that bypass? will i lose my steering controls? if i bypass the amp, i then not only need a new amp, but speakers too....
thanks
j
Old Aug 24, 2012 | 05:57 PM
Rottidog's Avatar
I have no idea, but posting it or asking for a Moderator to relocate this thread to Lighting & Electrical - Blazer Forum - Chevy Blazer Forums may help.
Old Aug 25, 2012 | 11:13 AM
rriddle3's Avatar
*Moved to 'Audio/Video Electronics'*
Old Aug 26, 2012 | 08:23 PM
hvkkid's Avatar
hvkkid is on a distinguished road
I'm almost positive removing the amp and replacing it with the same stock amp, or a conversion kit from crutchfield wouldnt hurt your steering controls in any way. The steering controls run from the steering wheel modules directly to the back of the radio. Only way you could lose the steering wheel controls is if you swapped out the stock radio for an aftermarket that didnt come with the wires to reconnect the wheel controls. IF you just change the amp, you wont have issues with the steering wheel controls.
Old Aug 27, 2012 | 12:01 PM
guitarsjm's Avatar
thanks guys thus far.... at least i know if i opt for another amp; speakers then have to go too... i get to keep steering controls... but still stuck on figuring how to even get the oem amp out to swap for another oem. it has 2 multi wire plugs and one of them, the larger of the 2 is a B@$ch to get/wiggle out while its mounted. if any of you pros have figured out how to get one of these out without damage to the surroundings, i greatly appreciate that. whilst i tried to do that, i just could not find a way to do that without a darn sawzall.... the amps 2 plugs-what are they each for; one i presume is strictly for speakers... the other, power for amp----and? i only ask that if i have no alternative other than to switch to another brand amp. i dont have a wire diagram/pin out for this amp. switching amps still seems a bit of a nitemare and also costs me a good deal more since i have to get ALL new speakers and that entails a good deal more work and possible dash damage that i would really rather avoid. so, with all that weighing in, i think the oem-oem swap seems my best, simplest and least costly option. all i need then is the know how to get the amp out.
thanks
Old Oct 12, 2012 | 02:10 AM
SubbinBlazer's Avatar
SubbinBlazer is on a distinguished road
Did you decide on replacing the front door woofers? If so, how much do you want for the front door woofers? PM me or EMail: adrenalinejunkie87 @ hotmail com Thanks
Old Oct 13, 2012 | 11:48 AM
guitarsjm's Avatar
hey...
dont really know yet as veh is in shop gettn new heads and gasket job... blew up on us a week ago... ugh..what a nitemare.. but great mechanic doin entire job for 1200 flat...heads valves.... alll redone...
speakers.... still havent gotten round to replacin amp which no one has yet to tell me how to get out! door woofers are, like most other things in doors are riveted...and i just got door panels all repaired and back on nice n neat... bitch to take em off without damaging them .... will let you know... just not yet... but... how much would you pay for em? may be worth it for me lol
Old Oct 13, 2012 | 01:28 PM
Glad everything is working out for ya'. There's a guy that can get the set for $20 from a local junkyard. Maybe I will try looking at my local junkyard before anything.
unpredictable1
Oct 26, 2014 04:12 AM
liltittle62
Dec 26, 2010 03:55 PM
stevengrc
Feb 5, 2009 09:19 PM
LAWDOG
Oct 22, 2008 01:03 PM
89LX
Aug 17, 2007 04:12 PM
