False Flooring
Old Aug 7, 2006 | 01:04 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default False Flooring
Alright here we go. I'm coming to you guys for something once (LOL) but yea Im thinking of building a false floor with some design in it!
I'm doing this for an upcoming show that i NEED a box lol. And my amps pretty big soooo i dont anywhere to mount it so false floor. Run wires underneath and have it come up.
Does anyone know how to do this? I'd love tips and also if theres a tutorial somewhere I'd lovee that too!
HOOOOOOOKKKKKKKK MMMMMEEEEEEEE UUUUUUUPPPPPPPPPP!
hahahahaha
Old Aug 7, 2006 | 01:13 PM
Default RE: False Flooring
Well, other than the obvious (carpeting, wood products, screws, etc), I would think you just need to build the substructure, then lay over some plywood. I would use some 1" by 2" pine boards for the substructure making a grid to hold the floor up, drilling whatever holes for wires you need. You may want to pull up the carpeting underneith to make sure that you on solid footing so nothing moves. Once you have the substructure in, use some cardboard to get the side details and transfer it onto some plywood. Use a jig-saw to cut out the plywood floor and check the fit, allowing some room for carpeting to roll over the edges. Finish it off with carpeting to match your interior (or whatever).
Only thing you really need to remember is amp placement when making the substructure and cut a hole for the amp out of the plywood floor. Mount the amp to the floor of the truck. I would try to get as large of a peice of cardboard as you can (and get a few of them) so that you can make the floor out of cardboard first and tweak it until it fits just right around the sides and around the amp. Then move on to the plywood.
As always, measure twice, cut once! Plywood is getting more and more expensive!
Old Aug 16, 2006 | 04:08 AM
djremix's Avatar
djremix is an unknown quantity at this point
I have a false floor in mine...measure, draw on cardboard, cut, transfer to plywood or MDF, cut install...you can run wires underneat if you want to, determine where you'll place amps, drill, screw amp and box on, you're done!
Picture 1 - DONE (with raised flames)
Picture 2
Picture 3 - installed
Picture 4-5 - finished uninstalled
[IMG]local://upfiles/2816/F8E6828C40224BD0B38FCA11E50DED88.jpg[/IMG]
[IMG]local://upfiles/2816/2307ED614CC74BFE9ADE1D79D12A846C.jpg[/IMG]
[IMG]local://upfiles/2816/223F1AEC5FD143CC81E13FEB77A1921D.jpg[/IMG]
[IMG]local://upfiles/2816/4B5816DD67514735A263C4DCB9D19407.jpg[/IMG]
[IMG]local://upfiles/2816/24DBC910815E491DAAE6C11A115A5AD6.jpg[/IMG]
Old Aug 16, 2006 | 09:56 PM
blazin97's Avatar
blazin97 is on a distinguished road
djremix that looks awesome. great job.
Old Aug 16, 2006 | 11:25 PM
XBlazer01's Avatar
ORIGINAL: blazin97
xFREAKIN 2!!!!
That does look good.
I LOVE the raised flames!
Old Aug 16, 2006 | 11:54 PM
flowmasta's Avatar
flowmasta is an unknown quantity at this point
hmm i think they did the headliner on pimp my ride like that........but x if u wanna go a different way........u remember that pimp my ride where they had the tour van for some rock group.....and the floor they did plexi glass with some hall of fame underneath.......you should do that......but have shapes laid out under the glass with some neons to make your trunk go bump and bright..
Old Aug 17, 2006 | 12:06 AM
XBlazer01's Avatar
I have a total of 9 strobes in the back. I could do that.... good idea. hmmmm........................
We'll see. Maybe put the amp down under the glass. Expose it. mmmmm Orion 2500D Guts
Old Aug 17, 2006 | 03:55 AM
djremix's Avatar
If you do put ANY electronics under a plexi, make sure you ventilate it with fans or kepp it open somewhere so air can circulate otherwise something will overheat!
Old Aug 17, 2006 | 03:56 AM
djremix's Avatar
TY
Old Aug 17, 2006 | 11:42 AM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
yeah that looks great! not sure about the color but i LOVE the work!!!
thibault116
Sep 24, 2013 11:38 AM
kenjkun
Mar 14, 2010 03:36 AM
fla_blazer4x4
Apr 14, 2008 06:16 PM
HCCAFan
Feb 5, 2007 10:35 PM
