feed back threw subs? fix it help
Old Feb 7, 2010 | 04:33 PM
sevendust4774's Avatar
sevendust4774 is on a distinguished road
Default feed back threw subs? fix it help
i know its a really common s10 and blazer thing i get feedback threw the subs like the motor and turnsignal noise, when it used to do it i could click the door lock back and forth and it would stop. but now its a constant annoyance. the amp is grounded very well please help!
Old Feb 7, 2010 | 07:53 PM
crashhole's Avatar
crashhole is on a distinguished road
you need to check the ground on the radio its self. I would also do the big 3 under the hood.
Old Feb 7, 2010 | 08:08 PM
zedartwo's Avatar
Yup, ground on the radio is big. And if that doesn't help, sorry to say, turn down your gain.
Old Feb 7, 2010 | 08:49 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
What is the amp grounded to? Tell us more about your system.
Old Feb 8, 2010 | 10:05 AM
Unlimitedsp's Avatar
I had the same problem with my system. Even after the big 3. I used a set of RCA Noise Isolator's on the amps and it stopped the feedback coming thru.
Old Feb 8, 2010 | 02:46 PM
MTopper's Avatar
I had the same problem. i fixed it by grounding the RCA cables to the radio itself. i took the red RCA, cut the plastic casing, trimmed the plastic around that and ran 18 gauge wire from that and twisted it around one of the radio's chassis screws and tightened it back down. worked great until i upgraded the RCA cables to higher end JL audio cables.
sorry if i confused you with that. i can reexplain it if need be
95jblaze
Aug 27, 2011 03:46 PM
CraigSnedeker
Jun 6, 2011 08:55 PM
tiw1990
Jun 2, 2011 03:06 AM
ruditron
Nov 30, 2009 11:38 PM
pinktruck
Sep 4, 2007 08:24 PM
