A few sub questions
Old Oct 15, 2011 | 12:29 AM
  #21
MTopper's Avatar
id you get dual 4 ohm subs, you're only options are to either wire them both down to a 1 ohm, 4 ohm or 16 ohm load. with that amp, you would need to do a 4 ohm load. 16 is never applicable.
if you need help figuring out how to wire subs together and such use:
Subwoofer Wiring Diagrams, Two 4 ohm Dual Voice Coil (DVC) Speakers
Old Oct 15, 2011 | 11:27 AM
  #22
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
These subs are dual voice coil 4 ohm so cant you wire them to 1 ohm, 2 ohm, 4 ohm, or 8 ohm? i thought i read something about that but i could have forgotten. ill take a look at that site too
Edit: just kidding i looked it up, only way to wire dual voice coil subs to 2 ohm is with a 2 channel amp.
Old Oct 16, 2011 | 08:52 PM
  #23
MTopper's Avatar
to a final two ohm load, you would either need a 2 channel amp or 2 separate mono block amps.
1/(1/4 + 1/4) = 2 ohms
1/(1/2 + 1/2) = 1 ohms final load
just throwing the math out there for if you want to figre it out later on your own
Flip01002003
Nov 22, 2011 01:31 AM
chris015
Oct 2, 2011 03:01 PM
Zasder
Jan 7, 2008 06:29 PM
blazinblack
Nov 12, 2007 11:45 PM
firechicken 383
May 1, 2006 08:26 PM
