Ground wire kit?
Old Dec 4, 2006 | 03:06 PM
burcham's Avatar
burcham is an unknown quantity at this point
Default Ground wire kit?
Does anyone have a ground wiring kit that can tell me if the purchase is worth it or not?
I searched around and cant really find the answers im looking for.
Are there specific points that the wires HAVE to be on to work correctly? Or just need to be grounded to engine, frame and etc? just curious
98 blazer 2wd mostly stock
functional hood scoop
custom hood paint job
cold air intake
K&n drycharger
thats about it
Old Dec 4, 2006 | 03:12 PM
jagblazer01's Avatar
Default RE: Ground wire kit?
what exactly are you trying to ground?
Old Dec 4, 2006 | 03:58 PM
I think it's talking about the 'BIG 3'.
*Moving to Audio/Visual* for better exposure.
Old Dec 4, 2006 | 04:00 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
A ground should be on bare metal for a good reliable ground.
Frame is the best. but you can sand down a bolt somewhere and ground it at that. just take enough paint off to help it ground properly
Thanks for movin it Kyle
EDIT:
If we are pertaining this to the big 3 upgrade then information is located here
https://blazerforum.com/m_28516/tm.htm
let us know if thats what you meant. if not post up and we'll help ya
Old Dec 4, 2006 | 05:48 PM
burcham's Avatar
Well by taking multiple wires from the neg. battery and grounding them to different parts of the car should..
" **Strong up performance of ignition system ..............**
**Stabilizes the engine at high RPM's ......................... **
**Smoother idling and improved starting .................. **
**Better fuel mileage with improved combustion .....**
**HELP PREVENT POWER LOSS AND ENSURE TOP PERFORMANCE OF IGNITION AND OTHER COMPONENTS**
**LOWER ELECTRIC RESISTANCE AND INCREASE THE EFFECTIVENESS OF THE ENTIRE **ELECTRICAL SYSTEM** "
i was just wandering if there were specific points the wires should be or if anyone has installed them before?
Was curious to how much of a improvement there is.
Old Dec 5, 2006 | 02:29 AM
blazinloud's Avatar
ummmm, dont expect to blow your mind......voltage might not dip as far when stressed
eljorgin
May 21, 2019 10:04 PM
cide
May 1, 2009 01:07 PM
ChevyRacing88
Mar 15, 2008 04:32 PM
88s10Blazer
Jan 3, 2007 01:13 AM
88s10Blazer
Jul 23, 2006 06:52 PM
