Grounding down 2001 jimmy
Old Apr 25, 2011 | 05:38 AM
92Jimmy01's Avatar
92Jimmy01 is on a distinguished road
Default Grounding down 2001 jimmy
what is the best spots to ground down my system??? i got 2 amps and 4 12s
Old Apr 25, 2011 | 12:46 PM
altoncustomtech's Avatar
Ground both amps to the same point, wherever is closest to their location. Use a stainless steel bolt a little longer than you need, then on the bottom side run a ground wire from the bottom of the body/bolt to the frame of the truck. It's about as solid a ground as one can get IMO. Don't forget to do the BIG 3 and ground the battery to the frame as well.
mjgraham
Oct 23, 2011 08:53 AM
Dano01
Dec 12, 2010 04:35 PM
99blaz
Apr 11, 2010 11:40 PM
Big O
Jan 31, 2010 09:29 PM
phil01ss
May 29, 2006 09:21 AM
