How do you read the dash board volt gauge?
Old Nov 6, 2013 | 05:15 PM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
Default How do you read the dash board volt gauge?
the middle says 14 volts , but what are the lines around it? 1 volt each? or .5 half volt each?
Old Nov 6, 2013 | 09:04 PM
richphotos's Avatar
umm..... I think they are 1 volt each. Because when I have the truck off on accessorie, its at the point where it would flash they battery light, and that means it would be at 12v.
But I have a first gen with a digital cluster.
Old Nov 7, 2013 | 07:35 PM
how can we be 100 percent sure? this is on the second gen cluster...
Old Nov 7, 2013 | 08:16 PM
richphotos's Avatar
I guess the only way to be 100% sure would be getting a digital volt gauge and hooking it to the battery and mounting it in the dash.
You can also always find out by seeing what the dash is at, and testing at the battery with a DMM (digital multimeter) positive from the DMM to the positive on the battery, and then ground the DMM to the chassis (firewall ect) Not the negative on the battery
kevinph
Feb 25, 2019 09:24 PM
dman001948
Nov 11, 2014 12:10 PM
SnowDaddy
May 25, 2012 10:50 AM
rmitch
Jul 11, 2011 06:28 PM
Numba1Sean
Oct 3, 2008 09:42 AM
