P1886: new solenoids, good grounds, good volt @ fuse, help!
Old Dec 10, 2011 | 12:45 PM
Rselarep's Avatar
Rselarep is on a distinguished road
Default P1886: new solenoids, good grounds, good volt @ fuse, help!
1996 blazer 4wd 4.3
I replaced the solenoids, checked all the grounds and wiring @ the harness, had the right voltage @ the tranny fuse (good ignition switch) and the code is still back!
Anyone have any idea whats going on? Where else can I look?
Old Dec 10, 2011 | 02:09 PM
pettyfog's Avatar
Well, here's a guy had the same problem..
Trans OBD II Code P1886 Trouble. - Car Forums and Automotive Chat
My guess, if it's not wiring, and it seems to shift fine manually it's probably in the valve body.
Did you recently have a fluid change?
Old Dec 10, 2011 | 09:15 PM
Blazer Steve's Avatar
Blazer Steve is on a distinguished road
Give Transgo a call
Product/Tech Support/Contact:
Give our technicians a call at (626)-443-7451
8:00am to 4:30pm Monday-Friday "Pacific Time" zone
"CLOSED for LUNCH from 12:00pm-1:00pm" daily.
Old Dec 11, 2011 | 03:54 AM
Rselarep's Avatar
I changed the fluids and filter when I swapped in the new solenoids, would a new valve body be expensive? Could I clean out mine?
When I put in the new solenoids the code came back immediately when I turned the blazer on and put it in drive. It does shift fine through all the gears manually.
Old Dec 11, 2011 | 07:14 AM
P.Martin's Avatar
P.Martin is on a distinguished road
Hello!
95 was PWM .99 Case Diameter 10-15 Ohm
96 was On/Off .89 Case Diameter 20-31 Ohm
Check resistance on Trans.connector between Pin E and S
( 20-31 Ohm or a bit more for a weak internal harness...)
Check Pin N (Range A) to Gnd = Open ore 250k up
Pin P (Range B) to Gnd = 5 Ohm..
Pin R (Range C) to Gnd = Open
mfg Martin
Tommer2
Jul 16, 2015 01:16 PM
wadenvk
Jan 14, 2014 06:31 PM
riggankl
Jun 28, 2011 05:01 AM
akira19
Feb 16, 2010 09:15 AM
midnightride_69
Nov 5, 2009 08:11 PM
