HELP!!! Replaced Factory CD player...Now REAR Speakers DEAD??
Old Oct 12, 2011 | 12:46 PM
00BlazerGuy's Avatar
00BlazerGuy is on a distinguished road
Default HELP!!! Replaced Factory CD player...Now REAR Speakers DEAD??
I'm installing this on a 2000 Blazer, no Bose. I replaced the factory CD player with an aftermarket Sony CD player, and have the Sony to GM wiring adapter (goes into the back of the new CD deck directly into the GM wiring harness...worked fine on a 99' Blazer. Bought with the CD player). I took this out of a working 99' Blazer with same factory unit and everything worked fine then.
The only difference is that the 2000 Blazer also has a Tape Cassette in the front of the center console under the dash. The rear of the factory CD player had both of the rear pin jacks occupied, this was not the case on the 99' Blazer. Does this secondary jack (the fewer pin one) have something to do with the Cassette player? Also, would not having this installed in the new CD player cause the rear speakers not to work? I need help!!! I have to have this working asap.
I also know it's not the new CD player because I plugged the factory CD player back in, and they still didn't work, but I couldn't get the secondary adapter to plug back in without tearing it all apart.
HELP!!!
Old Oct 12, 2011 | 02:23 PM
bigcountry58's Avatar
bigcountry58 is on a distinguished road
It would appear to me you need a second harness, I know on my 2003 I bought from crutchfield came with the wrong harness, however I did not do the install. There may be a different adapter that includes both harness connections into the one slot.
I am guessing the 99 only had 4 speakers where your 00 has 6.
Old Oct 12, 2011 | 02:26 PM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
easiest way to check is:
jump front speaker wire to rear wire and see if they work
Old Oct 12, 2011 | 03:29 PM
I just reinstalled it exactly how it was before I touched it, and they still don't work...so I did something, or something happened.
Are the rear speakers powered speakers? I don't see "Bose" anywhere so I don't believe this is a Bose system. I called the local shop and they said it would have powered speakers, but I'm thinking that's only the case if it's the Bose system. Is that true?
Does the speaker wire from the rear of the CD play right directly the speakers? Or is there a relay of some kind?
If they are powered in a non-Bose setup, is there a fuse somewhere I could've blown?
Old Oct 12, 2011 | 05:20 PM
coolasice's Avatar
coolasice will become famous soon enough
rear speakers are known for blowing out... probably toasted by the new deck, mine were blown when I got it... still have yet to replace them
94s10blazin
Aug 10, 2013 01:00 PM
kickme005
Aug 16, 2010 06:33 PM
kickme005
Jul 8, 2010 08:40 AM
yukonmedic
Feb 13, 2008 03:58 PM
fnirish
Sep 15, 2006 02:08 PM
