hooking up rca's an remote
is it possible to hook the rca's an remote wire up so the stock head unit in a 2000 blazer if so how do u do it im not new to car audio but i have never hooked the amp an stuff to the stock radio before
you need to buy a LOC (Line Output Converter) which will allow you to have RCAs for a factory headunit. as far as a remote wire, you will have to tap into the exisiting harness somewhere that has switched power
Make sure your positive it is the right yellow wire the airbag system is yellow wiring to and if you try to splice into it you'll likely get a broken nose.
Spectreblazer
Mar 9, 2010 07:43 PM
ftwflh
Dec 27, 2008 05:43 AM
