hooking up rca's an remote
Old Mar 12, 2009 | 10:16 PM
spankyy's Avatar
spankyy is an unknown quantity at this point
Default hooking up rca's an remote
is it possible to hook the rca's an remote wire up so the stock head unit in a 2000 blazer if so how do u do it im not new to car audio but i have never hooked the amp an stuff to the stock radio before
Old Mar 13, 2009 | 07:56 AM
jagblazer01's Avatar
you need to buy a LOC (Line Output Converter) which will allow you to have RCAs for a factory headunit. as far as a remote wire, you will have to tap into the exisiting harness somewhere that has switched power
Old Mar 13, 2009 | 12:14 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
if you want you could run it to your fuse box, i ran it to the wiper fuse.
Old Mar 18, 2009 | 09:31 PM
spankyy's Avatar
what way would u guys think would be the best way i just what to make sure it works good
Old Mar 18, 2009 | 10:13 PM
hillbillyinOhio's Avatar
Tie into the Yellow (larger gauge) wire at the radio. That is your trucks actual switched 12volt wire. That would be the best, but wiper fuse ok as well.
Old Mar 18, 2009 | 11:59 PM
NoPh33rRaCiNg's Avatar
NoPh33rRaCiNg is an unknown quantity at this point
there are line out converters that have an automatic turn on, so you dont need to tap into a 12v source to make your own remote turn on wire. i have one in my girls acura
Old Mar 27, 2009 | 09:02 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Make sure your positive it is the right yellow wire the airbag system is yellow wiring to and if you try to splice into it you'll likely get a broken nose.
20004wdblazer
Jun 4, 2010 12:43 PM
Spectreblazer
Mar 9, 2010 07:43 PM
6700
Feb 9, 2010 07:54 PM
Crestwood1001
May 26, 2009 08:16 PM
ftwflh
Dec 27, 2008 05:43 AM
