hot wire
Old Dec 26, 2007 | 04:32 PM
04blazin's Avatar
04blazin is an unknown quantity at this point
Default hot wire
ok i have my subs installed and they are working great, the only problem is im not sure what the best place is to run the hot wire. right now i have it going through my doorjam on the passenger side, although i was told that isnt a good place for it because it can ground out. i looked in the passenger side footwells, but i cant see a place where it can be fed through. if anybody can help me out it would be greatly apprciated. thanks alot!
Old Dec 26, 2007 | 04:36 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Default RE: hot wire
There should be a grommet on the passenger floorboard under the carpet toward the firewall...If you cant find a spot you can always just drill a hole int he firewall or floorboard and bring your wire through. Just remember that if you drill a hole you will need to use a rubber plastic grommet to prevent the wire from stripping and grounding on the metal walls....
Old Dec 26, 2007 | 05:35 PM
hillbillyinOhio's Avatar
the grommet that cloak is referring to is right above the top edge of the carpet on the passenger side. the antenna wire runs through the same hole.
Old Dec 26, 2007 | 06:06 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
ORIGINAL: hillbillyinOhio
thats where mine is at, it was pretty easy to find. the doorjam is definately not a good place for it, my buddy did that and his asctually started a small fire, nothing major, but you should run it through the firewall asap
stevenhousden
Jul 6, 2014 05:56 PM
Mandrwj
Apr 10, 2011 07:32 PM
88_s10
Jan 15, 2011 05:04 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
big_red_dre
May 14, 2007 07:50 PM
