How to avoid door panel vibrations from speakers?
Old May 19, 2007 | 01:33 AM
bleepstreet's Avatar
bleepstreet is an unknown quantity at this point
Default How to avoid door panel vibrations from speakers?
I just upgraded from the stock speakers in my 1998 blazer to a set of 4 6.5" infinity reference speakers in the doors. The sound is amazing but when I play songs with more bass the door panels vibrate. I am thinking about cutting out holes in the door panels and putting on the including grills to avoid any door panel contact which should hopefully stop a lot of the vibration. This would obviously work well on the front doors which have a nice circular pattern for the speaker vents. However the rear doors have a square vent pattern for the speakers. How can I make this look like a clean install after cutting holes in my door panels?
Old May 19, 2007 | 09:35 AM
viper4559's Avatar
viper4559 is an unknown quantity at this point
Default RE: How to avoid door panel vibrations from speakers?
My guess would be that just cutting the holes so the speaker does not touch the door panel will still give you the same result. It has been mentioned in the forums that taking small thick pieces of faom padding and putting them inside your door will help with the vibration issues. I plan on doing this when I install my new speakers....gotta get the money first.
Old May 19, 2007 | 10:57 PM
getonerd's Avatar
getonerd is an unknown quantity at this point
You can get some Damping Spray http://www.partsexpress.com/pe/showd...number=268-250or some sound dampening Sheets http://www.partsexpress.com/pe/showd...number=268-010
i would go with the spray because you can put it anywhere
its like bedliner in a can
Old May 22, 2007 | 05:08 PM
The foam padding sounds like it would be a good option. Where can I buy this stuff?
Old May 22, 2007 | 05:14 PM
hillbillyinOhio's Avatar
most parts stores should have foam tape.
Old May 30, 2007 | 07:34 AM
Gitzen's Avatar
Gitzen is an unknown quantity at this point
dynomat
Old Jun 5, 2007 | 03:22 PM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
x2 for dynomat, i was ghetto and used rolled up paper towels for the time being.
Old Jun 5, 2007 | 10:55 PM
viper4559's Avatar
ORIGINAL: TheBrettster
That is amazing! [sm=bling.gif][sm=happybounce.gif]
Old Jun 5, 2007 | 11:14 PM
Yea i just ordered 5 sheets of dynomat, damn thing was 100 bucks[:'(]
Old Jun 5, 2007 | 11:35 PM
fatmat and hushmat are cheaper alternatives. do the same thing. or you can use peal and seal from home depot or lowes.
cxrob
18
Dec 26, 2011 03:24 AM
jeffpatz87
Oct 23, 2010 11:14 PM
CustomBlazer0047
Jun 26, 2010 05:33 PM
DeeZee
Jun 9, 2010 11:05 PM
DCFluX
Oct 12, 2006 02:52 PM
