How to connect amp power cable to battery
i use a dual terminal batt and use the top post for the starter and truck wiring then use the side post for power wire i have ran, i second that using a copper lug, crimp it on for a good mechanical connection and then solder it for a good electrical connection. if you have a first gen blazer there is a hole on the passenger side just above the carpet and below your main harness that you can run your power wire thru its the antenna wire hole
Where did you get it and how much was it? I cant connect the ring terminal thing because the screw wont screw back in. I know how to run the wires I just dont know how to connect it to the battery.
JohnBarJB
Sep 28, 2020 07:34 PM
lazer2000
Sep 16, 2012 11:00 PM
bdubs
Apr 27, 2009 05:13 PM
Jimmy_Boy
Jan 16, 2008 05:30 PM
broke33
Mar 18, 2007 08:03 PM
