How do the quick connect transmission cooler lines attach to the 4L60E tranny?
Old Mar 17, 2007 | 08:20 PM
broke33's Avatar
broke33 is an unknown quantity at this point
Default How do the quick connect transmission cooler lines attach to the 4L60E tranny?
I just purchased a 1996 Chevy Blazer 4x4 and it had a front pumpeal leak. I pulled the trans out, replaced the seal and Im putting it back in. I have the bellhousing bolted up, but I cant figure out how to get the transmission lines to connect. They have these little spring clips and the lines are a compression fit. I push the lines in as hard as I can with one hand while taking the other hand to push in these spring clips. I cant get them in. Is there something Im missing? Do I need a special tool?
thanks
Old Mar 17, 2007 | 08:25 PM
Chevy Lover's Avatar
Default RE: How do the quick connect transmission cooler lines attach to the 4L60E tranny?
Install the clips into the connector, then push the line into the connector. Give the line a pull to make sure it's snapped in secure.
Old Mar 17, 2007 | 08:28 PM
Damn! Beat me to it!!
Old Mar 18, 2007 | 08:03 PM
broke33's Avatar
Thanks for the info, but I cant get these lines to snap in. How hard do I need to push? Is it easier to unscrew the adpaters on the side of the trans, snap the lines in, then screw the adapters back in?
porkfriedrice
Sep 27, 2024 01:08 AM
InsanePyro
Oct 17, 2014 09:11 AM
bearsfaninwisc
Jan 7, 2012 08:32 AM
Jonboy
Jun 7, 2010 06:24 AM
Jetfixer
Jul 11, 2006 05:02 AM
