How to connect amp power cable to battery
Old Mar 10, 2012 | 09:48 AM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default How to connect amp power cable to battery
How do I do this???
Old Mar 10, 2012 | 11:27 AM
CenTexBiker's Avatar
CenTexBiker is on a distinguished road
run the power cable through firewall, secure to inner fender. connect to positive on battery. make sure you run an inline fuse on that power cable
Old Mar 10, 2012 | 11:51 AM
Thogert's Avatar
^x2 And I used one of these to attach it to the battery wire attachment.
I got mine at Autozone 2 for $5.
Old Mar 10, 2012 | 03:40 PM
mattjphoto's Avatar
mattjphoto is on a distinguished road
I had to purchase an extender for my battery terminal.
Old Mar 10, 2012 | 07:58 PM
serrasalmus's Avatar
serrasalmus is on a distinguished road
i use a dual terminal batt and use the top post for the starter and truck wiring then use the side post for power wire i have ran, i second that using a copper lug, crimp it on for a good mechanical connection and then solder it for a good electrical connection. if you have a first gen blazer there is a hole on the passenger side just above the carpet and below your main harness that you can run your power wire thru its the antenna wire hole
Old Mar 10, 2012 | 07:59 PM
Where did you get it and how much was it? I cant connect the ring terminal thing because the screw wont screw back in. I know how to run the wires I just dont know how to connect it to the battery.
Old Mar 10, 2012 | 09:37 PM
if the screw is too short, get one that is 1/4 in longer and run a washer behind it
Old Mar 11, 2012 | 12:03 AM
Defiant's Avatar
Defiant is on a distinguished road
You can pick up a terminal extender at pretty much any auto parts store. I got mine at autozone for like 5 bucks. Just go check out the battery section and they should be there.
Old Mar 11, 2012 | 07:13 AM
pettyfog's Avatar
https://www.google.com/search?q=gm+b...minal+extender
JohnBarJB
Sep 28, 2020 07:34 PM
lazer2000
Sep 16, 2012 11:00 PM
bdubs
Apr 27, 2009 05:13 PM
Jimmy_Boy
Jan 16, 2008 05:30 PM
broke33
Mar 18, 2007 08:03 PM
