How to install a high/low adapter for amp?
Old Aug 12, 2009 | 04:31 AM
dontai's Avatar
dontai is on a distinguished road
Default How to install a high/low adapter for amp?
I am trying to install a sub into my car without buying a headunit and I am having trouble wiring it up with the adapter. I didnt know if you wire it from the stock radio or if you can just tap into the rear speaker. Whats is the best setup for this?
Old Sep 13, 2009 | 09:32 PM
Crestwood1001's Avatar
Crestwood1001 is on a distinguished road
Its possible to tap into the rears, I did but my rears were blown so i just pulled the wire through the rubber going into the door and added wire and ran it to the back, look up a wiring diagram and go to the back of the headunit and match up left positive and negitive with the wires on the adapter, same on the other side.
Old Sep 18, 2009 | 04:11 AM
pmpnu2's Avatar
pmpnu2 is on a distinguished road
i would tap into the rears as well, thats probly gonna be the easiest...
Old Sep 20, 2009 | 10:41 PM
2000 BRAVADA's Avatar
2000 BRAVADA is on a distinguished road
You can also use a PAC interface which will also give you front and rear rca. I am running JL 300w for mids & highs and two JL 500w amps for each JL sub. All with stock radio.
jdiaz
Sep 26, 2023 11:29 PM
JohnBarJB
Sep 28, 2020 07:34 PM
Streetracer94
Oct 29, 2018 09:33 AM
concretecowbot
Feb 16, 2012 01:32 PM
LioNiNoiL
Aug 4, 2011 02:47 AM
