How to wire new fog lights
Hey i just got some new fog lights the other day and i dont know how to wire them. they are mounted now just for looks but i dont know where to go from there. i have a g1 91' blazer thanks
RE: How to wire new fog lights
pic of foglight? how many wires are coming off the back....3?
yea there are three wires
ok....one is ground...one is constant power and one is switched. what color are they?
Ground, Black usually goes to anything metal on your truck.
The Hot (Usually Red) goes to your battery and switch.
The Feed (Usually White) goes to your lights and switch.
Run it through and make sure its clear of obstructions, and then get the wires in the dash, where you can take it apart, mount a switch, wire them up.
i knew the black and red but sometimes they use green as switched power too....
can u post a diagram? that would be awsome lol
i drew up a diagrm to wire it into stock fog light wiring all you should need is the switch for stock lights the wires already exist in my 2000 zr2 and should be in yours factories from what ive seen use the same wiring harness they just dont put in the switch or the lights making it really easy to tap into for us plus you will have the fog light indicator on the cluster work and you wont need to drill a hole for a toggle switch that doesnt match interior
i just cant figure out how to get the pic on here if you could tell me how to do that ill post it or if you have a chiltons or haynes i could explain it
somebody corroct me if im wrong which im sure would happen anyways this will only work if the factory did install the wiring for the lights they just left out the actual lights and switch like they did mine
i havent done 3 wire fog lights before only 2 so im not sure if the relay is in the light or not but if the relay is in the light itself you should be able to ground the black hopefully just wire it into where the stock plug is where the lights would be if it had them stock run the red or constant to a fuse to the battery then plug the white/remote to the purple /white wire and it should work as if it were stock
http://s129.photobucket.com/albums/p...ghtwiring2.jpg
if you dont have the stock wires here is a diagram
