HU problem
Old Jan 21, 2007 | 01:55 PM
kelraes's Avatar
kelraes is an unknown quantity at this point
Default HU problem
I want to replace my stockHU with an aftermarket. I have the new deck and a wiring harness. The stock system is bose six speakerwith an amp between the front seats. my problem is the harness i have a metra 80-1858. I have been told i need the metra 70-1858 but i can not find it anywhere. Is there nany way i can make the harness i have work? Circuit city told me i would have to rewire the whole truck. If thats what i have to what do i need besides wire?
2001 Blazer Ls
2DR 4X4
4.3L Vortec
Bose system
Old Jan 21, 2007 | 03:15 PM
hillbillyinOhio's Avatar
Default RE: HU problem
as long as the black end plugs onto the factory plug, you are fine. just cut off the end iwth the clear 21 pin connector, and then just wire that up to new cd player!! sometimes you do have to rewire the whole truck. first try installing the cd player and just make sure that you hook up the blue wires to eachother, to turn the factory amp on.
If that doesn't work, post up and I will walk you through the re-wire
Old Jan 21, 2007 | 03:43 PM
kelraes's Avatar
I see the blue wire in the vehicles harness the only blue wire from the deck is the remoet wire is this the correct wire?
Old Jan 21, 2007 | 03:56 PM
yes, that will turn on the amp
hotrodsbyg
Aug 15, 2011 11:47 AM
96realwe
Dec 10, 2010 09:19 AM
English5
Jul 16, 2010 11:11 AM
Confuused69
Aug 2, 2009 11:53 PM
Daytripper540
Mar 29, 2007 03:54 PM
