i found the subs
Old Aug 24, 2006 | 11:19 AM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
Default i found the subs
I did it. i finally found a sub i liked, then i found someone with one, and i really like even more now. The Sub, Power Acoustic **** 15 @ 2600 watt rms.i heard a single in a cavy with a 1600 watt Crunch amp. it slammed. So i am going to put 4 of them in a blazer, then hook it to a set of PA 2400 watt rms it should be crazy
Old Aug 24, 2006 | 11:22 AM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: i found the subs
NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO
BAD BAD BAD!
No lie dude. STAY AWAY FROM IT!
Xtucking has 2 with like 1400 to each sub in his S-10. Only doin a 134.6! STAY AWAY FROM PA!
The amp is good. Sub=poop!
But in reality the PA amp does about 1800@1 ohm
PA overrates there stuff ALOT
Old Aug 24, 2006 | 11:32 AM
well then, what do you run?
Old Aug 24, 2006 | 11:37 AM
XBlazer01's Avatar
currently at the moment 1 sidewiner with the Orion 2500D wired at 2 ohms in a prefab sealed box with no speaker terminal lol!
New box comin later this week tho
But seriously for the 200 bux for those PA's spend it else where man. I mean i wouldnt lie to you about it.
Old Aug 24, 2006 | 11:46 AM
have you heard the Hifonics Goliath 6400 watt 12's? i was also looking at 4 of those (or the 15" version) with 2x 2000 watt rms Brutus amps.
Old Aug 24, 2006 | 12:00 PM
XBlazer01's Avatar
honestly myself. I havent heard much about hifonics subs.
Its been overshadowed by there amps.
Def do the 2 brutus amps.
Subs is kinda hmmmmm ya know. Gotta do some research on them before i coudl tell ya on that man. Hell if u can do some RE's ur in business lol
Old Aug 24, 2006 | 12:13 PM
well, my team does Treo Engineering over RE. Same type, expenxive and overly powerful. but i no they pound hard.
Old Aug 24, 2006 | 12:15 PM
XBlazer01's Avatar
def. either or man. they're both high end companies! lol
Old Aug 24, 2006 | 01:27 PM
hillbillyinOhio's Avatar
i will vouch for treo later tonight, after I get everything hooked up.
Old Aug 25, 2006 | 06:19 AM
FatRyan's Avatar
FatRyan is an unknown quantity at this point
PA and hifonics are definatly overrated. not high quality companys by any means. but you gotta compare price to output. if your only paying 200 bux for an amp when it only puts out 1900watts as opposed to the rated 2500watts (for example), yes, its overrated, but YES its also a great bang for the buck. thats what makes these companies somewhat popular. they overated, but theyre cheap enough to make up for it...usually. not my cup of tea, but def worth it if you want alot of power for cheap
TimmyBlaze
Dec 23, 2010 11:01 PM
thrash902
Jan 28, 2010 06:58 PM
DS01blazer
Nov 8, 2005 12:06 AM
Freekstile
Aug 19, 2005 04:40 PM
dobbist
May 22, 2005 04:48 AM
