I just brought a subwoofer with speaker and amp with it.
There should actually be lights in there already. I bought an identical prebuilt unit like that from a friend many years ago and there was a little switch inside the terminal on the back of the box that controlled the lights.
To be honest, I never liked having the lights on. They were bright enough that there was a blue glow in the entire cargo area which made it difficult to see out the back window. There were also reflections from the lights and mirrors inside against the glass that got annoying.
cool mod you could do with the lights is run a relay to the positive terminal to your subs (acts as the switch) power source (you should already have that and the ground) and then a wire from the relay to the light. this way your light will come on and off every time your sub hits. Thinking about doing this mod myself.
Which is a worst advice on here. I want to know for sure because I don't want to start a fire in my truck. I have to go and get a RCA wire for stero and just got a Sony cd player and 4 speakers from my cousin in law. I will post the cd and speakers that I just got that I will install in my Blazer sometimes in the next 2 weeks.
It is like saying the wiring in your vehicle is a fire hazard and you shouldn't drive it because it might result in a fire.
um negative. It would be like plugging a speaker directly in to a wall outlet. ok, maybe not that drastic, but same concept. There is a right way and a wrong way to wire things. connecting lights directly to speakers is definitely the wrong way.
