Just purchased CB. Need a clean install method.
Old Aug 16, 2008 | 10:33 PM
elementalnature's Avatar
elementalnature is an unknown quantity at this point
Default Just purchased CB. Need a clean install method.
Topic explains it all mostly. I purchased a cheap Cobra radio and antenna.. now I need a cleaner method of installing it. Plan to do it Monday at school so I can have some access to decent tools. This is basically what I need:
[ul][*] A wire that is switched and won't interfere with the signal of the CB. Radio seems to work except when I roll my windows up or down and moving the power seat. I need the color of the wire please.[*] Need some ideas for mounting locations. I have mine mounted to the driver side switch panel that controls the lights but it's in the way of everything.[*] Also need an idea for running cables and hiding them.
[/ul]
Any help is appreciated and anyone in Russellville Kentucky area who wants to chat chances are you'll find me.
Old Aug 17, 2008 | 12:44 AM
WolfPack's Avatar
Default RE: Just purchased CB. Need a clean install method.
I mounted mine beneath the radio, center of the dash. Not sure if you a similar spot on the 1st gens. I tapped power to the cigarette lighter (I wanted constant power so I can use with the truck off), and got a nice ground on the firewall...at least I hope its a nice ground..
I hid all excess wires beneath the center console. I do get a bit of interference with the window motors, but I kinda blame a less than perfect ground...it works for my purposes though
Old Aug 17, 2008 | 09:06 AM
Well it's "dirty" wired in. I thought about the ash tray below the radio. Removing it and mounting it there. From there I might go to your idea of tapping the cigarette lighter. But I wonder if using the cell phone charger will caused interference with anything. Oh well, any other ideas to bounce off of? That sounds like a good idea there Wolfpack and I am going to go give that a shot. Appreciate the idea Wolfpack.
Old Aug 17, 2008 | 11:52 AM
whiteblaze's Avatar
whiteblaze is an unknown quantity at this point
Also try a cigarette lighter adapter you can buy at canadian tire/maby walmart, thats what i used but i still have interference with the power windows as well. I think your gonna get that no matter what but i could be wrong.
Old Aug 25, 2008 | 07:51 PM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
i had my cb grounded to the body mount under the truck and a direct power off the positive on the battery and i had it mounted in the center console the only wire that you could see was my coax doin out the tail gate to get my 102" whip. i got the cb hooked up in the silverado 2 weekends ago i just have to get some pics of it. here a pic of how the cb was mounted in the jimmy
jimmyboy
aka silveradoboy
Old Aug 25, 2008 | 08:42 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
Here is a pic when I was installing mine. I cut the trim piece above the center console (Below the radio) and I fabed up a new AC line so it would work. In the pic it was even wired up to the fuse box, just need the antenna to be hooked up and the mic.
ski.dive
Jan 23, 2014 01:35 PM
jebardeors
Sep 18, 2011 05:44 PM
siccnezz
Mar 10, 2011 10:35 PM
Twist'd_MP
Lowering Tech
May 17, 2009 03:48 AM
