Looking into security system possibilities
Old Feb 22, 2006 | 11:45 PM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
Default Looking into security system possibilities
Hello. My older brother used to have a 94 ford probe, (he bought it used) and it had a kill switch, where, in order to start it, there was a little button that you would have to push. Anybody know anything about this? Thanks. I don't want a full blown security system, just a kill switch maybe.
EDIT i found a good wiring diagram on the12volt.com. I think if i do it i'll just do a toggle switch for the ignition wire that i can turn on and off when i want. How heavy-duty a switch would i need?
Old Feb 23, 2006 | 09:34 PM
audiophyl's Avatar
audiophyl is an unknown quantity at this point
Default RE: Looking into security system possibilities
If you are wanting to put a switch in, I would recommend at least a switch with a rating of 30 amps or more. I personally would recommend just buying an alarm, as they will typically save you some money off your insurance. Additionally, they are a much safer solution to your situation.
Hope this helps!
Old Feb 23, 2006 | 10:13 PM
FatRyan's Avatar
FatRyan is an unknown quantity at this point
ORIGINAL: audiophyl
Hope this helps!
yeah, every thief in the world knows to look for a kill switch. get an alarm with starter kill. the starter will not work no matter what if your alarm was activated or disengaged improperly. its almost failsafe
Old Feb 24, 2006 | 12:38 AM
4lowlife's Avatar
I wouldn't worry about it unless you owned a CLS 55 AMG or something
Old Feb 24, 2006 | 12:36 PM
Canadian88's Avatar
Hahaha, that's my other car. i wish Thanks for the responses.
Old Feb 24, 2006 | 02:53 PM
catalin's Avatar
catalin is an unknown quantity at this point
All 99 and newer have built-in immobilizers. On the dash you have a light that displays the word 'security' I believe. Not trying to be disrespectful but that means it's better than any switch you can add to the vehicle.
The best thing you can do is add an aftermarket alarm on top of that immobilizer and you're set.
Old Feb 24, 2006 | 02:55 PM
Canadian88's Avatar
How is the immobilizer activated?
Old Feb 25, 2006 | 05:18 AM
catalin's Avatar
It's passive as soon as you turn the vehicle off. The key needs to fit in the cylinder at which point it activates a trigger/mechanism in the ignition tumbler. Vehicle will run but only with your working keys.
Old Feb 25, 2006 | 02:27 PM
Canadian88's Avatar
i see. thanks.
Beatrice79
Feb 20, 2015 07:29 PM
89Blazer
Jul 9, 2009 07:36 PM
f1yrod
Apr 13, 2008 04:48 PM
falconfixer86261
Jul 31, 2007 05:13 PM
tycobb280
Sep 28, 2006 12:21 AM
