motor noise in stereo
Old Jul 8, 2011 | 10:39 AM
coyote64's Avatar
coyote64 is on a distinguished road
Default motor noise in stereo
Hi, I have owned this blazer about 8 months now and love it. A couple weeks ago I noticed motor noise in the radio. Everything is stock. It is intermittent and you might describe it as ticking noise. I replaced the plugs and wires last weekend. I just read the post about removing the dash, so I am ready for that. My question is should I go for the loose connection on the radio, or could there be an electrical problem in the engine?
Thanks,
Old Jul 8, 2011 | 12:26 PM
Gorton's Avatar
Gorton is on a distinguished road
Mine has been doing this for about 6 months now, making a winding noise that gets louder the higher the rpm's are.
Old Jul 10, 2011 | 04:38 PM
buckrogers's Avatar
buckrogers is on a distinguished road
does this happen with just radio or cds too. did it happen right after you change the plugs and wires.
Old Jul 11, 2011 | 08:55 AM
coyote64's Avatar
The noise is only on the radio and not the CD. I notice it on FM and not AM. It changes with the RPMs. I noticed the problem several weeks ago. I changed the plugs (used AC iridium) and wires last weekend thinking that might help. It didn't.
Old Jul 11, 2011 | 11:15 AM
Magmotor's Avatar
Magmotor is on a distinguished road
In my '93 manual it says noise from the engine heard over the radio is coming from a faulty Ignition Control Module inside the distributor and only happens on the FM channel...it also says to move any wires away from the distributor as far as you can...look for carbon build up inside the cap...a black spot on the rotor...oil leads on the terminals inside the cap or a faulty coil.....hope this helps a little...
Old Jul 16, 2011 | 11:30 AM
coyote64's Avatar
Update - I just replaced the ignition coil, cap and rotor. There was some corrosion in the cap and on the rotor contact. Preliminary results are good. No more noise in the radio. Engine runs smooth.
Old Nov 20, 2011 | 11:09 PM
ryguy013's Avatar
ryguy013 is on a distinguished road
Default re:
the noise that comes through the radio that sounds like the engine is called ground noise, its usually a problem with a connection not being grounded properly somewhere in the system and can also be caused by the dis cap or alternator, if you have an aftermarket stereo that is amped, then you can get rid of the noise by simply putting a ground loop isolator inbetween the rca out of the deck and the rca into the amp
LesMyer
38
Jan 9, 2020 11:45 AM
rob1621
Feb 29, 2008 08:15 PM
chevyman30571
Feb 26, 2008 06:32 PM
jumper02
Jun 8, 2006 12:09 AM
93LT
Dec 9, 2005 05:17 PM
