Mounting Air Tank 02 ZR2
I hooked up a set of Hadley air horns and I put the 5 gallon tank in the back. I am looking for a relatively inexpensive way to mount it (ie. keep it from flying around in an emergency situation). It runs lengthwise behind the passenger back seat. Will post pics later, but if anyone has any generic ideas, they would be appreciated.
EDIT: Pics posted below.
here and here
I don't want to bolt it flat to the floor because I want to be able to access the drain plug - located on the bottom of the tank.
here and here
bolt it down through the floor
The tank is basically a cylinder without any places to mount it flat. Bolting to the floor wouldn't really work for it. I also need to access the drain plug, located on the bottom of the tank.
bend a thin strip of steel around it and bolt that to the floof
Fab up some feet for it that bolt to the floor yet have enough heighth to give you access to the drain plug.
ur pics dont work
they work fine for me...
Work for me as well, but not when clicked from the links above. I had to copy & paste into a new browser tab.
Does it have mounts like that on both sides?? Looks like it was intended to be mounted between the frame rails somewhere...
I would get some tank mounts with clamp style hold downs to support it on the floor and then pipe up a ball valve to the drain, locating it somewhere accessible. You could even have a pipe extending from the ball valve to under the truck somewhere to vent the tank outside the passenger compartment when you wanted to drain off any condensation.
They don't work for me either, but I x2 the bending some steel around the tank and bolting that to the floor...
Thanks for the recommendations. If you're having trouble with the pics, right click, select Copy Link Location, and then paste it. This will get around Tripod's silly linking block.
I think I might go the "feet" route. This may work the best for me.
