Need some help understanding something...
Old Nov 9, 2007 | 12:02 AM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default Need some help understanding something...
So I got the Polk db6501 and the Polk db691. They are both rated for 100w rms @ 4 ohm. Now I dont want to go with a 4 channel amp because those cost more. So I can bridge the 4 speakers right? Like the two on the right and two on the left or rear and front? What specs would I need out of a 2 channel amp? For example: 200w rms x 2 @ 2 ohm
I just dont understand what the specs are after bridging...
Old Nov 9, 2007 | 06:56 AM
hillbillyinOhio's Avatar
Default RE: Need some help understanding something...
yes, you can bridge the right and left sides together, or fronts and backs together. 4 channel amps really arent that much more, but you will have to look for 2 channel amps that do about 150 -200 watts per channel at 2 ohms. It will be considerably easier to find a 4 channel that will do that with two or the 4 channels bridged at 2 ohms.
Kicker Zx350.4
Rockford Fosgate T4004
Old Nov 9, 2007 | 01:47 PM
How do you like your Kicker Zx350.4 ?
Some people said it just sounded better when bridged too...
Old Nov 9, 2007 | 02:18 PM
Also, if my speakers are 4 ohm could I do the following:
200 RMS x 2 @ 4ohm
Someone told me the lower the OHM the more noise you will get so you want to keep running it at 4 ohm. If I did that above would I be fine?
Old Nov 9, 2007 | 09:52 PM
Mr Blazer LT's Avatar
Mr Blazer LT is an unknown quantity at this point
The lower the ohm, the lower the resistance. Doesn't really involve noise at all. Getting power at a lower 2 or 1 ohmsis better than at 4 or 8 ohms.
Old Nov 9, 2007 | 10:16 PM
ORIGINAL: Mr Blazer LT
yes, the lower the ohm the lower the resistance, true. but the other two statements are totally false. More noise is introduced at a lower ohm load,a nd amps are more effecient at a higher ohm load. amps are happier at a higher load. a higher ohm load will produce a cleaner ouput, less heat for the amp. Keep in mind, that doubling your power only increases your output (sound) by 3db.
Old Nov 10, 2007 | 10:28 AM
blazinloud's Avatar
ya, I wish I had an amp that did 2500rms at 8ohms, that would be sweet.
Old Nov 10, 2007 | 11:11 AM
i have an amp that does about 1800 at 4 ohms.
krunk357
Tires and Wheels
Apr 30, 2012 02:38 AM
TZFBird
Sep 11, 2010 08:33 AM
NewFirstGen
Dec 1, 2009 04:19 PM
noom14921992
Nov 12, 2008 09:23 PM
jackson1717
Oct 10, 2008 09:10 PM
