neons
Old Oct 23, 2005 | 11:48 PM
blazerrider101's Avatar
blazerrider101 is an unknown quantity at this point
Default neons
i have a neon light and a plasma light what do i hook it up to so i can switch iton and off without draining my batt
Old Oct 24, 2005 | 12:30 AM
drkmelvin's Avatar
drkmelvin is an unknown quantity at this point
Default RE: neons
Well, I would go to a spot in the fuse block. There are accessory ports in the block that arn't being used, usually labled acc, or batt. You can use a test light to determine whether it is hot constantly or you need to turn the key. For example, your 4-way flashers are constant... you don't need to turn the key to use them, but your power windows are switched... they don't work unless you turn the key. Or, you can go the hack...err, I mean easy way, and tape the wires to a 12 volt plug and plug it in to the cig. lighter.
Old Oct 27, 2005 | 09:47 PM
snowboardingtripp's Avatar
snowboardingtripp is an unknown quantity at this point
Default RE: neons
well when i got my streetglow minies for inside i went about it the fast and easy way. on your dash you have the cig lighter that folds down go in there and take that apart and then wire the wires straight to that it may not be profesional but it works and then when you get time you can go back and do it the right way. i did it that way cuz i live in alaska and it was the winter time and staying outside tolong can get a little cold
~Tripp
Old Oct 29, 2005 | 04:53 AM
drkmelvin's Avatar
Default RE: neons
I want to go to Alaska !!
WhiteTie BlackJacket
Aug 30, 2007 07:07 PM
mortalum620
Aug 30, 2007 02:27 PM
EuroGoldLS
Jul 29, 2007 11:23 AM
blazinloud
Feb 1, 2007 11:22 AM
98BlackBlazer
Nov 7, 2006 08:38 PM
