New Gear!
well finally, here they are.......
did a comparison with a ppi C1 12 (great sq)
and a MA 8
![](https://i135.photobucket.com/albums/q159/blazinloud/DSC00271.jpg)
![](https://i135.photobucket.com/albums/q159/blazinloud/DSC00269.jpg)
![](https://i135.photobucket.com/albums/q159/blazinloud/DSC00275.jpg)
![](https://i135.photobucket.com/albums/q159/blazinloud/DSC00273.jpg)
They'll be getting around 800 watts each.
and a MA 8
nice subs man. those things can pound. prefab box???
Those look freakin awesome, about how much do those run, and what kind of gear do you need to power them right? Definately put up a pic when you are done installing them.
-Lenny
-Lenny
they're cheaper than hell! got the 2 for just over $300 they're rated at 500rms......but for them to really sing I'd suggest more....
hillbilly I will be getting a box built pretty quick......but I wanted something a little different.......like a snailshell.......but i doubt that will happen....shops prolly want crazy money for that.
what do you recommend? slotted at 32hz? subs up port back......?
think a 145 is in my sights?
![Big Grin](https://blazerforum.com/forum/images/smilies/biggrin.gif)
yea, straight crx or subs up port to pass side. if you can keep up the voltage for that amp, 143.
yea, it already drops pretty good, voltage wise......
I was reading on roe that a 2nd battery wont do much good considering I will still be dropping below 13 volts.......I will be switching to 1/0 wiring soon buuut, I dont think that will do much.
Like having a 2nd batt. wont stabalize my voltage, right?
143 is kinda weak [&:]
The second batt will help keep the voltage up (twice the current capacity, after all) but a beefier alt will definitely do the trick.
ya but there soooooo expensive ![Frown](https://blazerforum.com/forum/images/smilies/frown.gif)
anyone know what like 160amp or 200amp ho alt goes for......like whats the cheapest one?
I know I could email excessiveamperage.........but thought maybe one of u guys could tell me a little quicker.
sweet subs man.....good luck with everything. i have a kinetik 800 ill sell if your interested in doing a second batt.
I will run a 2nd battery if its worth it.......but the things I read on roe kinda led meaway........
um, so is that like 800ca, or 800cca? what does the 800 stand for?
I seen LOTS off ppl running those so they must be pretty decent.
what r u asking for it? it dosent matter if you run 2 totally different batteries? I think the one I have under the hood is a 2 year old acdelco, its like 7 or 750 cca i think.....might be less.......
how old is the kinetic? I will buy it, like I said, if i'll see any gain from it......
thanks jag.
thanks jag.
