No sound in speaker problems
Hello everyone
I have a '97 Blazer and there is no sound coming out of the speakers. Everything on the actual stereo deck works but no sound from speakers. When I first got it about 6 months ago once in a while a little bit of sound would come in and out from one of the rear speakers but now nothing at all.
I pulled the dash off and checked the wires on the back of the deck and one of the door panels and checked the speaker area and everything looks ok from what i can see.
Can anyone give me some advice on more things to check out?
yes it is a factory radio and no i do not own a tester.
how should i check it with a tester exactly. what part do u hold it on.
someone did tell me it sounded like a speaker problem a while ago but is it really that possible that they would all go at the same time? can anyone point me in the direction of how to test the speakers. i'm really not good with electrical terms so the easiest way would be best.
thanks all
thanks all
See the link for testing a speaker with a 9V battery.
http://www.soundspeakerrepair.com/sp...+Instructions/
You really need to get yourself an inexpensive Digital Volt Meter. To check the speakers set the meter on Ohms and put the two leads on the + - speaker leads. You should get a reading very close to speaker rating 4, 8 or 10 Ohms. If you get no reading then either the speaker is bad or one of the wires is open. Do not measure any live voltage on the Ohm Scale or you will blow a fuse in the meter. You can set the meter to read DC Volts on the appropiate scale and check the output voltage from the head unit. If you have no voltage at all then there is an issue with the head unit or the wiring to the head unit. Once you learn how to use the multi-meter it will come in very handy for Auto & Home use. Have you checked the fuses for the head unit. There is usually at least two fuses one for the radio lights and one for power. I not sure what the normal output voltage is for speaker leads maybe someone else can chime in. I know the voltage changes with the volume setting.
i do not know what chevy did wrong with second gens but they have had several problems with rear speakers goin out there are several solutions to this many people have gone and bought cheap aftermarket speakers and installed them and it fixed the problem which for some reason this has fixed alot of them but if you take the same speaker from the blazer and put them in another vehicle or even home stereo thay work fine? wierd but it happens also if hat is not the problem it occasionally is the deck or worste case which is still fixable is bad wires
c3478493
Feb 3, 2014 02:56 PM
Horton
Aug 18, 2013 09:52 AM
gERgMan
Sep 6, 2008 07:27 PM
vdog
Jan 10, 2007 04:46 PM
