Noise? How do I stop it?
So my radio has quite a bit of noise in the radio. When I turn my HIDS on I get quite a bit of noise in the system until the lights warm up. I also get a lot more static in the radio then my OEM one did. Should I find some kind of noise filter? Also, there is a loud setting on my HU. When I enable it the system sounds so much better I think. When I disable it, it sounds muffled and low quality. Is it bad to have my radio on Loud?
RE: Noise? How do I stop it?
it is with subs in the back. My guess is they actually hooked up the dimmer/illumination wire. that will usually cause havoc when the lights are on. what kind of radio again???
hillbilly are you saying it is bad to have your loud on your head unit when subs are in the back of the blazer? i always leave my dimmer wire unhooked
its bad to use the loud option anytime. All it does is send dirty signal to your subs.
Noise can be introduced in many ways. here is a short list.
bad RCAs
RCAs run next to power wires
Bad ground on the HU
Bad ground on the amps
ground loop
bad RCAs
ground loop
Well the subs sound fine. The whole reason I am using Loud is because my speakers sound better. When loud is disabled, my speakers sound muffled.
ya, my speakers really sound "warmer" with the loud setting on, but it makes the subs **** like jack hammers......so i leave it off or on low.....depends on the music.....
i use my loud when i really **** them but fot most of the time i leave it off or down. mine has a loud setting from 1 to 4. i never go over 3.
Will it damage my system though if I have it on loud and I play it loud? Like I wonger what the manufactures description of that feature is...
What does the illuminator wire look like?
ORIGINAL: nofear17bmx
"Loud" Setting should only be used at low volumes. This may sound like a catch22 but the loud is meant to push more signal to the speakers at a low volume for clarity. Using the loud feature at higher volumes can potentially overdrive your speakers resulting in damage...
The illumination wire should be the orange or orange/white wire coming out of the back of your deck...It should be capped off and not connected. If its connected to a factory wire, cut this connection and cap both ends...
Anyone got any suggestions of which ones I should check first?
bad RCAs
ground loop
bad RCAs
ground loop
