Nominal Impedance
Old Mar 28, 2007 | 12:14 AM
RCarp48's Avatar
RCarp48 is an unknown quantity at this point
Default Nominal Impedance
How bad is it that I have my impedance on my subs lower than my amp??
Old Mar 28, 2007 | 02:59 AM
hillbillyinOhio's Avatar
Default RE: Nominal Impedance
they re the same. If your subs are wired to 1 ohm, then the amp is at 1 ohm. 2 to 2, 4 to 4.
Old Mar 28, 2007 | 02:31 PM
viper4559's Avatar
viper4559 is an unknown quantity at this point
I thought that you had to have an amp that could handle the 1 ohm to wire your subs at 1 ohm?
Old Mar 28, 2007 | 02:40 PM
blazinloud's Avatar
thats true, but the wiring on your subs determines the load the amp see's
you cannot have your subs wired for 2 ohms and run your amp at 1 or any other variation. they must be the same.
Old Mar 28, 2007 | 06:57 PM
viper4559's Avatar
Right, so what I read from his question is "how bad is it that I wired my subs for (lets say as an example) 2 ohm and my amp is only a 4 ohm amp"
Does that make sense? I am reading that he wired his subs to an ohm level that his amp can't handle possibly.....
Old Mar 28, 2007 | 07:05 PM
correct, if you have a 1 ohm capable amp, and you can wire your subs to 1 ohm, then great. whatever you wire your subs up to, the amp will be at that same level. So, if you have dual 4 ohms vc/s then you r amp will either see a 2 or 8 ohm load. If you have dual 2 ohms subs, then your amp will either see a 1 or 4 ohm load. If you have 2 dual 2 ohm subs then your amp will see a 2 or 8 ohm load depending on how you wire them. If you have 2 dual 4 ohm subs, then your amp will either see a 1 ohm or 4 ohm load.
Old Mar 28, 2007 | 07:10 PM
viper4559's Avatar
Still, we would need to know what his amp can handle, then what he has them wired up to
Old Mar 28, 2007 | 07:25 PM
blazinloud's Avatar
for more specific help, what is the equipment?
Jaws
Oct 12, 2010 06:56 AM
portcqb
Sep 24, 2009 09:07 PM
splblazer
May 22, 2008 07:25 PM
