Poor FM reception
Old Jan 5, 2020 | 01:36 PM
Michael J Wyskida's Avatar
Michael J Wyskida is on a distinguished road
Default Poor FM reception
I decided to upgrade the sound system on my 1999 Blazer. I pulled the old cassette player and put in a moderately priced touch screen deck. The fm reception was crappy. It would waiver in and out sounding kind of muffled and back to clear reception. I thought perhaps the stock antenna wire was bad so I replaced the entire antenna and wire and that changed nothing. So then I assumed it was the budget stereo so I bought a better stereo and put it in and have the exact same issue. Anybody have any thoughts as to what is causing this?
Old Jan 5, 2020 | 07:50 PM
Lack of a proper ground perhaps for the coax to the antenna?? That you replaced the antenna means you likely did not have a break in the antenna cable.
Have you tried to test the OEM radio to see if it also is having FM reception issues? If yes or no, the answer might help point to the problem.
Old Jan 6, 2020 | 12:01 PM
Stock stereo work fine
Old Jan 6, 2020 | 07:45 PM
So the original radio works with the new antenna?
Old Jan 6, 2020 | 08:45 PM
Yes it does but I have tried 3 aftermarket stereos and they all have the same reception issue
Old Jan 7, 2020 | 02:45 AM
That is nuts. It has been awhile since I installed an aftermarket radio but one of the things I would think would not change is the connections to the antenna! Does the plug and receptacle for the new radios look the same as for the OEM?
xgiovannix12
Jul 17, 2013 07:56 PM
Blade_24k
Jul 11, 2012 01:24 PM
cochran07
Jan 19, 2011 01:33 AM
numus
Jan 18, 2010 07:12 AM
Kaffeene
Apr 23, 2007 04:15 AM
