Power
Old Mar 14, 2007 | 10:30 PM
TheGuardian08's Avatar
TheGuardian08 is an unknown quantity at this point
Default Power
Within the next 15 months I will be adding a strain to my electrical system and I'm wondering if my blazer can handle it.
What I have
XM Radio
Car Charger for my flashlight
What I plan to add:
Whelen 90watt Hide-a-way strobes
Whelen dual dash strobe
SHO-ME rear LED sticks (red/red)
Carson Siren/Speaker
Yaesu HAM radio
Radio Shack Scanner
Fog Lights
Will I need to upgrade my electrical system?
Old Mar 14, 2007 | 10:38 PM
blazinloud's Avatar
Default RE: Power
I think you will be fine.......the 'big 3' might help.....try a search.
its upgrading the wiring to a thicker wire. easy, and worth it imo.
you might have some voltage drop, shouldnt be too serious......you should see some of the amplifiers ppl run on these stock electrical systems
what was Jon running, something like 3200rms on the stock alty.......droppin to 9 volts and still held, till his amp took a crap.
Old Mar 14, 2007 | 10:39 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default RE: Power
Yea, I would say so. You might be able to get away by just doing "the big 3" but if your lights throb or flicker you may want to upgrade your alternator to somthing a little larger.
Old Mar 14, 2007 | 10:54 PM
Default RE: Power
thanks for the replies, i know it will be a while but id rather upgrade my electrical system now, then later when I'll have to drop lots of $$ at once
I suppose i could dump the dash strobes for LEDs to drop the power usage by a fair amount
Old Mar 14, 2007 | 11:03 PM
blazinloud's Avatar
Default RE: Power
could always just have ur alt rebuilt to.....but then again its a small case alty so heat buildup could be an issue.
Old Mar 14, 2007 | 11:17 PM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
Default RE: Power
You can buy a new chrome alternator - 140 amps. I think I will buy one in the near future.
Old Mar 15, 2007 | 08:25 AM
drperry's Avatar
Default RE: Power
I haven't had an issue with mine so far... The voltage when I have all my lights on drops to... 14... According to the volt meter...
You'll be fine on the stock setup... The 'Big 3' is always a good idea, even if that's the only mod you do to the electrical system...
I'm not sure of the wattage/amperage on the stuff you have there, but I'm probably a wee bit higher...
If I remember right, my driving lights total 310 watts... It's either 310, or 400.
My fogs total 220 watts.
When moving, even with my stereo cranked, the voltage stays above 14.
It might've dipped below 14 when I had the stereo cranked while stopped, with all my lights on... can't remember for sure anymore...
Old Mar 19, 2007 | 11:32 PM
Default RE: Power
thanks again
Old Mar 20, 2007 | 01:38 AM
nai0013's Avatar
nai0013 is an unknown quantity at this point
Default RE: Power
A deep cycle dry cell battery is always a good choice. Just remeber if you upgrade the alty you should run a new wire from it (bigger).
flipzat
Dec 2, 2009 04:05 PM
fresno99
Jul 31, 2009 08:12 PM
1991whiteoutblazer
Jan 8, 2009 08:17 PM
nate2003456
Jan 18, 2007 01:10 AM
freeman
Aug 23, 2005 10:55 PM
