power cable shenanigans
So im in the middle of pulling all of the old wiring out for a fresh install. amp, subs, new wiring.
My first speed bump is the shop that installed the original stuff did one hell of a job hiding the power cable, there isnt anything visable that i can see where they connected it to the battery and where its going into the dash for my life of me i cant find where it exits into the motor compartment.,..
anyone have any ideas on where i would most likely find the power wire under the hood judging from the picture?
second question would be whats the best method for hooking up the power cable. when i was younger i remember vaguely just going straight to the + terminal with some kind of connector
What you remember is still the best way to connect the positive lead for the amp. Just don't forget to fuse the wire as close to the battery as everything under the hood will allow you to mount it.
To me it looks as though the wire is heading straight for the main harness boot. The main wiring harness has a huge rubber boot that keeps the water/weather out of the cabin. It has a fair amount of room around it and a lot of people like to cut a little slit in the boot and pass the wire(s) through that and then put a dab of silicone around it (hopefully).
If they did indeed pass through on that side they might have connected the wire to the main post on the under hood fuse block instead of directly to the battery. Otherwise they would had to have ran the wire from that boot all the way around the engine compartment to the battery.
It's just a guess, but that's where I'm leaning toward what they did. If you take that bottom trim panel off that's hanging there in the picture you should be able to see up under the dash pretty easily at wherever that wire is going.
BTW, if that is how they installed that wire then beware there's probably other corners on the old install that have been cut. It's scary to think that people PAY shops for that kind of crappy work.
yeah, im not sure if its even open anymore that was around 8 years ago in my home town in texas heheh.
The cable comes off the pedal assembly. If I recall correctly, it'll just pop off. I pondered that myself a while back until I decided to look at the other end of the cable instead of the end with the release handle on it lol
TexasRider
May 30, 2013 09:10 AM
Squad-6
Apr 22, 2013 02:19 PM
