power wire?
Old Sep 1, 2007 | 04:44 PM
cameronp29's Avatar
cameronp29 is an unknown quantity at this point
Default power wire?
I did a search and found out how to get the power wire from my battery to the inside of my truck. I have a 2000 GMC Jimmy 2Dr. I found out that the easiest way is to run the wire from my battery to a grommet near your left foot on the passenger side. this is right??right? anyway I was wondering i have 4gauge wire. Is it best to run it down the side or straight down the middle. If i go down the middle i think that means all interior needs to come out. Is it possible to run the wire down the side? What do you recommend?
Old Sep 1, 2007 | 05:49 PM
Blazin_Jason's Avatar
Default RE: power wire?
I would pull the pass seat out and the back seat. Run the power wire down the middle. I just did that on my 89 Jimmy, but I ran 1/0. There was no way that the wire would go down the pass side. With your 4g, you might be able to. I would still say to go down the middle. Tape the wire down so it doesn't move on you later.
Old Sep 2, 2007 | 09:10 AM
ali1's Avatar
ali1 is an unknown quantity at this point
you can definately fit 4g on the side. I can see how blazinjason was having trouble getting the 1/0 on the side, but i got it done.
Old Sep 2, 2007 | 11:53 AM
hillbillyinOhio's Avatar
yes,like ali said, you can squeeze 4 ga under the panel, but when I did my many runs of 1/0 i just pulled out the passenger seat and ran them there.
Old Sep 2, 2007 | 05:20 PM
cameronp29's Avatar
well today i ran all my wires and i just pulled out the passenger seat and the back seats because i had to run 2 seperate power wires and i have to run new speaker wire and everything. were half way there after working today. we should finish up tomorow il take some pics of the finished product when were done. should be up by tomorow night.
chris015
Jul 8, 2012 01:19 AM
DJ 4x4
Sep 26, 2011 09:44 PM
bubba181x1
Mar 12, 2008 02:05 AM
alpinejimmy
Jan 20, 2006 09:38 AM
massaudio
Nov 17, 2004 11:22 AM
