Protecting wires from heat?
Old Nov 7, 2009 | 09:34 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Default Protecting wires from heat?
Im currious what kind of methods we can think up for protecting our aftermarket wiring projects from heat uderthe hood and around the exuast.
I use 2000 degree pyro sleeves for protecting my 4g power cable but at 20+ dollars per 3ft chunk it is a bit excesive for smaller wires.
so i was thinking about running wires through hoses? or pipes? what kinda suggestion does everyone have?
what kinda hose/tubing would work? my headers burn all my wires, lol. :-(
Old Nov 8, 2009 | 07:52 AM
Monkeyman's Avatar
Monkeyman is on a distinguished road
Reroute your wiring.
Old Nov 8, 2009 | 03:34 PM
Thats really helpfull productive advice, THAT HAS NOTHING TO DO WITH PROTECTING WIRES!
...Next
Also... I been looking at using rubberish fuel line hose, Its cheap and suppose to be rated for high heat.
Old Nov 8, 2009 | 04:32 PM
Well, the question (title) is "protecting wires from heat". I think what Monkeyman was getting at was, instead of going through costly means of protecting them in their current location, to try and route them differently as to not be affected by the heat.
In terms of what to put them in, there is some higher temp wire loom that can protect to some pretty good temperatures. You could also fab up an aluminum heat shield for the bundle.
In my opinion, if it is more than an inch or two that is going to be affected, a better solution is to move them to where they are not affected. Since this is custom wiring, routing them away from heat is quite easy on initial installation if though of. If this is an after thought, then it can be more complicated...
Old Nov 10, 2009 | 10:06 AM
richkcmo's Avatar
richkcmo is on a distinguished road
yep! i agree.
Old Nov 10, 2009 | 04:54 PM
Re-routing is not the issues, sorry if I was rude in my earlyer post.
These are wires that go across hot places. mostly single wires or pairs used for senders.
maxvamp
Oct 31, 2020 08:19 AM
Mrthelaxer
Mar 20, 2013 08:00 PM
mcaanda
Dec 15, 2009 08:31 PM
rogggg1020
Sep 24, 2008 06:53 AM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
