Quick Question
Old Aug 25, 2009 | 12:22 PM
Numba1Sean's Avatar
Numba1Sean is an unknown quantity at this point
Default Quick Question
has anyone ever had problems with hid's and ebay projector headlights. i got the ones with the halo on high beam. i changed the ballast and switched bulbs and the passenger side still has somewhat of a diff color to it (halogen looking just brighter). could it be a relay not delivering sufficent power or is the housing messed up?
Old Aug 25, 2009 | 05:29 PM
blazer blaze13's Avatar
blazer blaze13 is an unknown quantity at this point
yea my friends looked differnet like that for about a month or two then the halo on that side went out....
Old Aug 25, 2009 | 09:42 PM
Numba1Sean's Avatar
yea but the hids are the low beam projector not where the halo is.
I MIGHT have found the problem. looking at it closely, i found that both igniters on the bulbs were facing diff directions, one had the igniter at the bottom of the light and the other was sideways. the only thing that i saw that would have made the color diff is that the one that had the igniter at the bottom of the light had a liquid near it and the one that was sideways had the liquid looking stuff on a good portion of the bulb, now after a little fighting both bulbs have the igniter wire at the bottom lets see if that shifts that liquid stuff off the bulb surface a little more. i rambled a little bit so if nobody understands just say so and i will clarify better. On a side note should i make a breather hole for hid's, looks like there sealed pretty good.
Old Aug 26, 2009 | 09:23 PM
Numba1Sean's Avatar
yea that wasnt the problem still look the same tonight. maybe i will replace the relay.
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
88s10Blazer
Nov 10, 2006 05:49 PM
88s10Blazer
Sep 26, 2006 10:19 AM
athleticdawg26
Jul 30, 2006 02:43 AM
black19
Jul 2, 2006 11:58 PM
