radio
Old Nov 20, 2011 | 12:19 PM
tazz7002's Avatar
tazz7002 is on a distinguished road
Smile radio
is it common for the radio,sounds like its off station or ant is messed up ,does ant go bad a lot ,i have a 96 blazer,i like to keep orginal raio or is it best to put a after market one in,mine ia a factory cd radio,can u buy new factory ones anymore,or u think antenna bad,,its does it on all stations,like its off channel needs tune in..
Old Nov 23, 2011 | 03:51 AM
MTopper's Avatar
Two things.
proper english so we can understand your question better.
use a period instead of a comma so it isn't all one sentence.
Radios can go bad. you can get a replacement stock radio but, if you buy it new, it will cost you more than a good aftermarket radio will.
Old Nov 23, 2011 | 06:12 AM
pettyfog's Avatar
Actually radios do go bad. But antenna connections are more likely.
If ant is bad, AM is more affected than FM. In other words, if you can see the FM station tower the FM should sound fine even with flaky ant unless it's totally disconnected
If the sound in both is garbled on strong locals stations it's radio.
But the electronics dont wear out, per se. No moving parts. CD is another matter. But lots of people use them very little.
Junkyard is where you get OE radios
Old Nov 23, 2011 | 09:46 AM
tazz7002's Avatar
Smile radio
english aint my thing,,,,,putting a old supertuner in this thang,,,
Old Nov 24, 2011 | 04:01 AM
MTopper's Avatar
all i meant is use you instead of u, say antennae instead of ant. thats all. when i see ant, i think the little thing crawling on the ground. I have a pet peeve with using u, r, y, and so forth instead of you, are, why. It makes you sound "smrter" and such when you use the full word. AND, when you do, you'll get more help
Boiler20
Oct 19, 2013 03:53 PM
dan_t
Nov 25, 2010 08:35 PM
iamchevyman5
Nov 7, 2010 01:20 AM
black19
Jun 22, 2006 03:35 PM
